So I'm about to run wiring through my Gheenoe for my trolling motor. It's a 45 lbs. Minn Kota Riptide and pulls 42 max amps. When everything is said and done, the wiring will run between 15-20 ft. According to the charts on Minn Kota's website, if I go to 20 ft. I need to be running 4 awg wiring. Despite this, I'm just not sure if that's necessary. For one, there are hardly any TM plugs out there that are 4 awg compatible which shows how rare it is. For two, I'm assuming this protects you if you are running the TM on max speed for a long period of time.
Considering that the distance is probably closer to 15 ft and I'm not going to always be pulling the full 42 amps, I'm definitely leaning on just going with 6 awg. Anyone have any thoughts on this?
