21 - 39 of 39 Posts
I have a Rule 1100gph fully automatic cartridge style bilge pump in my Vantage. Incidentally, it is the same pump for my release well so if I needed, I could just swap them pretty quickly.
I will add why I can’t stand my Rule. It auto senses water. Well how can a pump work when it has intakes approximately 5/8 an inch high? Once water gets down to 5/8 an inch it sucks air no longer able to pull water it keeps cycling. I don’t mind that tiny amount of water in pump depression of hull but the sensing should not work below that level. I assume a float switch style would go on/off as that water moves with boat but pump can’t pick up water and air. So auto fuse is pulled for flats fishing.
I would hope the intake is below the float level. I wonder if rotating the pump / float 90deg might make it work better? What is your discharge hose route? Does it have a bend above the thru hull discharge to prevent all the water in the hose from running back into the bilge when the pump stops?
I went with Johnsons after all the poor reviews of the newer rules. No complaints thus far, but also not a long term review.
If you have the space, the best bet is to install two at different elevations. One that gets used all the time, and one that remains "fresh and ready."
I did this. I put a 500gpm Auto Rule at a low level, and a 1200GPM Attwood on a manual switch about 2" higher for taking waves over the bow crossing Lake Bourgne.
I have two plugs in my boat, one on either side of the tunnel. Can pump water out faster than it comes through the two 1" drain holes.
I didn't install it yet. I actually bought it to drain a pool. It was not ideal but it worked.
It's a 3/4" outlet but I hooked it to a 5/8" hose that ran 30+ feet away with 5ft of elevation, so it had to work much harder then if it were on a boat. It ran for like 2 days straight and drained I think 8000 gallons.
Sorry to derail- Just FYI,
Pumps have to work harder when the elevation change and resistance to flow is minimal. The more head/resistance, the less they flow and the less power they consume. I know this sounds counter intuitive, but its true.
Ha! Damn tough crowd. Had to ask. Soooo I guess that a no go. Ummm asking for a friend. LOL
I can see wanting to avoid putting screws in your hull but it’s worth a few dabs of adhesive. Good thing about th Johnson pumps is the motor cartridges drop in from the top so if it dies you won’t have to pry the housing up.
21 - 39 of 39 Posts
