Microskiff,
I’m hoping for some help in diagnosing a motor issue. I’ve got a 2015 Yamaha F60 that is sputtering and shutting off at idle. When this starts to occur, the bulb can be pumped to keep the motor running. Motor has no issue when running at higher RPM’s. Fuel water separator and fuel filter in canister on motor are both brand new. Fuel line is 1 piece from tank to engine except for at the separator. In-line filter between the fuel pump and the canister on engine is clear. I just replaced the fuel lift pump on the back of the block thinking it may be the problem and the problem persists. Seems like there may be some sort of fuel flow restriction that is preventing enough fuel from getting through at idle, but not creating issue at higher RPM’s?? Hoping for some thoughts so I can continue to troubleshoot.
Thanks.
Thanks.
