RTIC 52 Ultralight long term durability?
3.5K views 21 replies 13 participants last post by  greentide
#1 ·
Wanting to add a casting platform. Leaning towards RTIC 52 Ultralight with turnbuckle tie-downs.
Searched the previous discussions and see a few people have the RTIC ultralights.
I like the reduced weight and bigger internal volume compared to YETI 45.
I don’t keep fish that often, but sometimes some free-range organic fish hits the spot…
A second cooler is nice because, I believe you shouldn’t mix fish and beer in a cooler.
I haven’t seen one in person. Are they pretty solid? (I’m over 6ft and over 200 lbs), so not a “small boy”How are they holding up with extended use as casting platform?
Would also be interested if anyone has rigged up any sort of back/bar on them like the TunnelMaster guys make.
Thanks
Discussion starter · #3 ·
That just helps reduce the difficulty of choosing the color pallet for the skiff. Just hope that you don’t need to replace the cooler and they discontinue that color.
I assume the back rest is custom-made?
Discussion starter · #10 ·
6'2/215lbs. I have had a RTIC 52 Ultralight on the front of my Spyder FX19 for 4 years, no problems. You can stand on it no problem. It will hold, but I have had the lid give but always rebounds. The lid is not as strong as thick/strong as a Yeti 65 but will work. tiedowns work great also. I got a rod holder for it from coolerworks.com to make it work better for me.
Thanks. Good to know about the lid. I can stand on my igloo, but it flexes enough I think it would eventually cause issues.
Discussion starter · #18 ·
I went to the RTIC store. Leaning now towards the 32 instead of the 52. Only 13 pounds, and I have the 72 Igloo already for a big cooler. It’s definitely not as stable with smaller footprint, so would need to secure it well.
