61 - 80 of 129 Posts
So I'm running a jack plate I was thinking about going with a 4 blade aluminum prop. What will this do to the above numbers?
Go with the SRA3 prop. What rpm are you turning with your setup? I run the 10p and it is a great performer with my setup. With the micro jacker, SS is a must to raise the motor up high and still stay hooked up
So finally got to run my 2017 Yamaha F25 today. Here are the numbers I got. I haven't got a chance to set up the boat or distribute the weight properly so this wasn't with the boat loaded down or anything.
I got up 31mph at 5500 rpm going into the wind on my lake so there is no current. I never ran it at the top of the rpm range so I'm guessing I can get a couple more mph out of her. The engine is smooth running but rough at idle. Hole shot is decent figured it will get better when I'm able to put some weight forward. I will post more once I have a chance to dial it in. This is how it is set up as of now. GPS numbers were off of phone gps because I'm currently having problems with my dragonfly pro 7. But the numbers on the phone have been reliable in the past.
5500rpm with the stock 11p? I’d go down to at least a 10p to stay at 5500rpm. Honestly I’d go with the 9p and bump the rpm up to 5700-5800 to get the most performance out of the motor. That motor puts out more power at the top 300rpm range of the motor which is 5700-6000
I have the SRA 12 on my Spear Glade X with fixed jack @ 19"+ high on 16" transom with 5" offset and it turns 5850 @ 31-33 gps light. It stays hooked up pretty well except on hole shot when it cavitates a little getting up. My third prop brand tried, best of the bunch, tried : Solas, Turbo, Power Tec. All gave different speeds n performance, kept the PT and going in to my third year with it. Running shallow marsh mud bottoms caused rehubbing the prop, only issue to date. My motor is also thru bolted thru the transom and riser plate, I think the cavitation plate is 2"+ above the bottom. I hit the rev limiter with the Turbo Hot Shot 12", was in the mid/upper 6000 range, lots of ventilation and not much go. It topped out at 35 mph gps light load, not a good load prop, though it was the fastest.
So I got the jack plate put on and the motor mounted. It is possible to thru bolt the motor. I raised the motor 1&1/4” and the bolts were just high enough to miss the track. I feel confident this will never move
Yes I did the same thing. I also through bolted it after raising the motor. That put my motor 2in above the bottom. So that took 2in out of my my range of travel. I wanted my motor even with bottom of the boat.
5500 rpm isn't the top rpms I was getting. That was during break in. Wide open I was hitting rev limiter at 6100. I also ended up trimming the motor up one hole, which bumped me up a few rpms.
What did it sound or feel like when you hit the rev limiter? Since I added the microjacker, I have been able to turn higher rpm. I was out the other day and the tach read 6180rpm and the motor cut out for a second. It’s the first time I’ve experienced this and I assume that was the rev limiter. I haven’t tried to replicate the problem because I don’t want to put any unnecessary stress on the motor.
Yes I guess you could describe it like that. It was different than my Merc rev limiter. But the RPMs sounds about right.
Ok so I have got some more realistic numbers from my Yamaha F25. So total boat weight for these numbers is approx. 600lb with two people total weight 300lb so around 900lbs. I was running 29.6 to 30.2 on my Raymarine Dragonfly Pro. 6100 rpms with stock 11 1/4 pitch prop. Hole shot is decent. I have an atlas micro jacker i am running with the ACP just skimming the top of the waterline. I dont have power trim and tilt so I have the trim pin set for better running capabilities rather than hole shot. These numbers came from running the skiff in the lake behind my house so there is no current to effect the mph numbers. Hope this helps.
Preview of gallery image.
