Primer bulb goes flat
22K views 102 replies 25 participants last post by  11604
#1 ·
I picked up a mint condition gladesman last month and have had it out a few times the first time I took it out it ran for about 30 minutes then the primer bulb lost it's prime. I have replaced the tank,bulb,gas line and all fittings still having the same issue. The fuel tank is up front and the run is about 16 feet so my theroy is that the motor is having a hard time pulling the gas that far for reference the motor is a 05 Yami 15 4 stroke. What say you microskiffers?
#13 ·
Ok Jimmy, you answered your own question brother! 3/8” fuel hose and a 16’ run is your problem. The little pump can not pull the weight of the fuel that far! Drop down to a 5/16” fuel hose and your problem will most likely be remedied! You can test the theory by putting the tank in the back with a short hose and run it before replacing all the fuel line, but I am willing to bet a sammich that this is your problem!
#14 ·
If the bulb is sucked in after running a load, that’s because you are pulling more gas than air is entering the tank/vent. Basically a vacuum and at some point the fuel pump won’t pull any more. Everything works till it breaks. Don’t rule out tank or vent issue just because it used to work.
However I think Boatbrains knows more about boat motors than me.
#17 ·
my jonboat has tank up front, with an inline filter, when i get to bout a quarter tank, i start having issues as well. check fuel level.
Also
My hobie skiff did the same thing about 5 miles off ft lauderdale, bumping around made the fuel connector from the tank to fuel line got clogged wit a tiny piece of silicone... something is clogged.
Try running a smaller line too! im running 1/4 or 5/8 in both boats.
#23 ·
When under a load the motor is demanding more fuel and the pump is sucking harder. A lot of outboard issues don’t show themselves on the hose or at idle but when you put the hammer down they show themselves. I could see how too small a fuel hose would cause fuel delivery issues on a small outboard and a long tank run but why would the bulb go flat? My fuel hose on the 70 is 5/16” and the run is about 17’ because of high motor mounting.
#31 ·
Brand new fuel line no inner tube had that issue also before. It did the same thing with the old fuel line also I believe it is in the motor as suggested by someone else. I have decided to put the 25 on it and pull off the 15 that will definitely fix the problem as I know the 25 will pull the gas that far. Now I just need to see if a 9 gallon tank will fit under the front deck.
#37 ·
That full line you posted most certainly does have a liner, every B1-15 line has it with the exception of Sierra Silverado 4000 and a certain Gates love. Also, B1-15 is soft in general. Go to an A1-15. If your running long runs, you need LARGER hose. It has nothing to do with the weight of the fuel, but the pressure loss caused be fluid friction within the hose. I don't see the diameter as the issue however.
