I'm looking for a recommendation for a reel that balances well with an 8/9wt with adequate line capacity and a high retrieval rate. Current reels' arbors (Orvis Hydros) just isn't big enough once into the backing.
I've been in that situation many times in the Glades and can sympathize. I'd stop worrying about "balance" as it doesn't really mean anything and look for the features you want in a reel and match that to your rod. In the video linked below Nat Linville addresses reel weight and balance and it's worth a look. He's fishing a 4.5" 14oz Mako 9550 on his #9's so he's speaking from experience. A few years ago I started weighing and measuring my fly reels and others that I ran across and found that what's reported on manufacturer websites is unreliable to say the least. These days I don't worry about weight very much and I definitely don't worry about "balance." I find the right combination of pickup speed, frame width and reliability and go from there.One example this year was fishing for 40-60 lbs. tarpon with a 9wt and then a 125+ shows up unexpectedly. Caught it on a 9wt--rod had enough backbone for the job--but the reel complicated things. I get that the any 8wt/9wt reel would be overmatched in that situation, so a big part of my question was recommendations for larger reels that balance well on 8wt/9wt rods.
Define "balance" in terms of choosing the weight of your fly reel.Tailer said "These days I don't worry about weight very much and I definitely don't worry about "balance." I find the right combination of pickup speed, frame width and reliability and go from there."
Well you've got that rightGood luck to you, but IMHO a 14oz.reel plus whatever you've loaded it with would have an immediate effect on the balance of a 9wt.rod unless it's a proverbial broomstick.
....and I presume you're launching this out of a boat?
Please do expand. What are the criteria for “balance”? Surely if it’s as important as you imply and glaringly obvious to everyone else there must be some defining criteria for “balance”.The weight of a fly reel directly affects the balance of an outfit,and while this isn't a dedicated fly fishing forum,I'm sure that most members will know what a balanced outfit is,so I'm not going to expand on that.....
You can’t define it because it’s marketing copy written by folks like me to sell new gear every season.Sorry,I can't help you more than what I've posted...
+1 for the T-8. The Galvan G-8 has a sealed drag that is a T-8 on steroids. Galvan is great.Check out a Galvan T-8.
