Help with batteries - dedicated starting (got it down), okay to run 100 aH LiFePO4 12 volts for Trolling + as House?
820 views 6 replies 4 participants last post by  CoffeeRun
Just my 2 cents, you're overthinking a lot of this for a skiff. Get a dedicated trolling motor battery(100 aH 12 V LiFePO4) with a circuit breaker and use a good AGM battery with the required cold cranking amps for your motor, possibly a dual purpose if you like, and let that run everything else. Use your battery switch on your main battery to turn the main battery on and off when the boat is stored. The items you reference running with a potential "shared" battery don't really need to be shared. Your trolling motor battery should do just that. It's going to use a lot more juice than your GPS, rarely used running lights, and your bilge, which I think you will find is used less often than your running lights, especially on a skiff. In five years my bilge pump has never come on with the automatic float switch.
