FYI---barometer effects
4.5K views 20 replies 13 participants last post by  Dallas Furman
#1 ·
Effects on fish
All this is very interesting, of course, but how does barometric pressure affect fish? To find out, I consulted Spud Woodward, Assistant Director for the Georgia Department of Natural Resources Coastal Resources Division and an avid king mackerel and red drum fisherman.
While Woodward admits that there's no definitive answer for how a rising or falling barometer affects fish behavior, he has some thoughts based on his decades of marine research and some 15 years of tournament fishing.
According to Woodward, a fish senses pressure changes through its air bladder, and well in advance of humans. "Fish that have small air bladders, such as kings, Spanish mackerel, wahoo and dolphin, aren't as affected by barometric changes as those with large bladders, such as trout, redfish, tarpon, grouper and snapper," he says.
Check the Fishing Forecast
"That's because fish with small bladders have a body density that's closer to that of the surrounding water. They don't sense the pressure changes as dramatically, so their comfort levels aren't drastically altered. However, many things they eat have air bladders, and that alone could have a big impact on where you might find them and how they'll behave.
"Fish with large bladders quickly sense when the air pressure is dropping, because there's less pressure on their bladder. And when there's less pressure squeezing their bladders, the bladders expand a bit. When their bladders expand, fish become uncomfortable. They relieve their discomfort by moving lower in the water column or by absorbing extra gas in their bladders.
Because of the anatomical and physiological stresses exerted on them, they're not worried about eating. They're more concerned with trying to find a depth where they can stabilize their bladder pressure and feel good. Some species will settle to the bottom and ride out the change near structure. Fortunately for the fish - and fishermen - low pressure doesn't usually last long."
Low means slow
According to Woodward, fish are much more comfortable when there's stable high pressure, and tend to feed actively most anywhere within the water column. He also acknowledges the general cycles of high and low pressure and how fish react to them.
"Let's say we're experiencing a prolonged period of high pressure and the fishing has been good. Then a cold front heads our way. Ahead of the front is low pressure. The fish can sense that the barometer is about to drop. So, right before the high begins to dissipate and the barometer falls, the fish respond with a change in feeding patterns. They'll often feed heavily right before the pressure drops. As it does, they become more uncomfortable and feed less aggressively. When the front passes and high pressure moves back in, the fish may not feed aggressively for at least 24 hours, since they're still adjusting.
"However, it's a different story a day or two after a high settles back in. The fish will have had time to stabilize and an intense bite can occur. When the pressure changes again, such as when another front moves in, the cycle repeats itself."
When the barometer sinks below 30 inches off his home coast of Georgia, Woodward doesn't bother fishing for big kings in less than 70 feet of water, even if the fishing had been good in previous days. Instead, he fishes farther offshore, in deeper water, where he believes the pressure change may be less pronounced and the kings less affected than those closer to shore.
He also recognizes that the fish may be holding deeper in the water column during this period, and that he may have to experiment with the depth of his baits to score.
As Woodward mentioned, baitfish are also affected by barometric pressure. For example, falling pressure may force the bait to hold deeper and become less active, which would impact the fishing in the middle and upper levels of the water column.
Bass by the barometer
In New Jersey, Captain Terry Sullivan experiences similar behavior with striped bass. "There's nothing like it when we get inside that high-pressure bubble during the spring," says Sullivan. "That's when those brilliant, sunny days warm the bottom in the shallow backwaters. Usually on the third day of the high, the fish really turn on. These highs usually last three or four days before the weather changes."
Sullivan points out that one of his best nights of fishing came before an approaching front. With lightning flashing in the distance, the stripers turned on and aggressively struck the flies Sullivan and his charter clients were dead-drifting from their anchored boat.
"I've seen striped bass go on a wild feed right before the barometer began to drop," says Sullivan. "During summer, we get an upwelling effect ahead of a front. Right before our southeast wind shifts more southerly and begins to blow, which precedes the front, it triggers a hot bite locally. The fish sense that a change in weather is about to occur and feed heavily right before the front. Once the wind goes hard south, they shut down. I guess they know they won't be eating for a few days, so they have to gorge themselves."
Offshore effects
Barometric pressure affects things on the offshore grounds, too. I can recall a very slow day of dolphin trolling off South Florida one summer. As the afternoon progressed, a major thunderstorm began making its way off the land and threatening the offshore waters.
With the storm still miles away, a light, cool breeze sprang up. About the time we decided to retrieve our baits and take off, a school of dolphin charged out from underneath what had been a totally dead weed line. We hung around just long enough to boat 15 fish before the storm forced our departure.
During the winter off South Florida, sailfish use cold fronts to aid their southerly migration. In this case, the arrival of high pressure after a cold front can spur incredible fishing, whereas low pressure seems to curb the activity. Ray Rosher, one of Miami's leading charter captains, shared his thoughts on how high and low pressure affect sailfish.
"A lot of people think it's all wind direction that gets the sailfish moving and feeding, but it's high pressure as well," says Rosher. "For example, you can have a light wind and rising pressure and the bite will be on. When high pressure moves in, we're in a cold front and the wind is from a northerly direction. When we have a strong northerly wind opposing the northbound Gulf Stream, the fish rise to the surface and use the wind direction and waves to help propel them against the Stream's current. Those are the conditions that really get them moving south. When they're tailing on the surface, they're burning more energy. And since they're more active, they must eat more. This is when those red-hot bites materialize.
"Low pressure is often accompanied by wind and waves from the south, which push north with the Gulf Stream. The southbound sailfish are now prone to more resistance at the surface. There are no northerly swells or winds for them to use to their advantage when swimming against the Stream. During this stage, I believe the fish stay deep to conserve energy. When this occurs, my flat and deep lines get the most bites. A good example occurred recently when my co-captain, Alex Castellanos, caught five sails in calm conditions. The next day, the barometric pressure increased and the wind shifted around from the north. Alex caught and released 15 out of 16 sailfish in less than four hours!"
As mentioned, there are numerous factors that influence fish behavior, and any one of them can make the difference between success and failure. The best strategy, of course, is to plan your fishing days around the peak conditions for your particular area and the local species. Unfortunately, that's a luxury few of us have, but now you can also blame the barometer if you come home empty-handed!
#3 · (Edited)
I love fishing bluebird days with high pressure, there are fewer people on the water because they read articles like this and let it determine if they go fishing or not.
I am not trying to be difficult, I have just had so many epic days when it’s super high pressure it’s hard for me to believe it.
-EDIT-
After reading the rest I agree! I guess I am just so used to reading and hearing the typical “high pressure no catch, low pressure go catch” that I blocked it out.
#10 ·
If my ciphering is correct, a drop of 20 millibars would require the fish to move about six inches lower in the water column to compensate. Doesn't seem like that would explain the Kingfish example.
#12 ·
I have never done well the first few days after a cold front, those high skies bluebird days. I have read it is the effect of higher, more intense light penetration, that tends to push fish deeper in the water column. For me it seems more prevalent in fresh water lakes than the salt, but still for me it is tough in the salt. Maybe the wind is also playing a part, but whatever, a cold front normally is a big negative for me. Confidence maybe??
#16 ·
I have my best snook days (dark mornings and nights, really) when there is an approaching front or storm and the pressure is already dropping. When it coincides with the first part of a falling tide, even better! And some of my worst snook trips are during periods of high pressure.
#18 ·
I don’t believe that fish are as affected by barometric pressure as we think. I’ve talked to Dr Aaron Adams about it at length and he agrees. The pressure under the weight of water is much more than the pressure exerted by our atmosphere, and increases exponentially as you get deeper. There’s only one true scientific study that I know of that tested feeding habits of yellow perch against barometric pressure and found no relation. Going through my fishing journals I find a relation between temperatures and feeding habits, but not necessarily barometric pressure.
#20 ·
There are so many factors that can override the pressure aspect of it. I feel like pressure is only one part. Like Lee said, wind and the tides can override just about any aspect no matter the day. The only thing I will say in regards to when fish feed is that I have almost always noticed fish feed voraciously prior to a cold front and can be really lockjawed the day that cold front arrives. The day it arrives the pressure usually blasts thru the roof and you have those sunny bluebird sky days that can more often than not be VERY tough to fish. If there are two days that I'll choose to stay at home and do other stuff they are the first day of a cold snap and the day of and after a full moon. Every now and then though I get REAL hard up to fish and I go out on those days and surprise myself. I wrecked them on the last full moon day. You never know until you go, but you start to put together general patterns. If nothing else you aren't going to beat yourself up if you go out and the fishing is tough. Plus, it can still be a lot of fun to fish that bluebird sky day because you get to easily see every redfish turn his nose up at your bait.
#21 ·
I don't know much about the scientific affects of barometric pressure on fish, but in my own experience on those blue bird days I seem to be able to catch trout pretty regularly but redfish seem to be tough. Drop the pressure a tad and throw in a few clouds it seems to be a lot easier for both reds and trout.
