Here's the background -- 2002 Yamaha 30hp 2 stroke (short shaft, tiller, pull start, no T/T). Ran great for the original owner (friend's father). Sat outside lying down on a pallet for a few years, when I got it the motor wouldn't tilt and it would barely turn. Queue MAP gas, hydraulic press, angle grinders, lots of new parts -- bracket is good as new. Lots of new components all around (while we were in there...). Carbs and coils were replaced with (supposedly good) used units that looked very clean. New gaskets, float needles, fuel pump diaphragm, etc. Powerhead was removed and stripped, but the head was not separated from the crankcase. Idled well on muffs, timing was adjusted per manual.
First test run is great. Idle is too low, but good power for the first few minutes. Started seeing some bogging at higher throttle, like it's dropping a cylinder. Found that the thermo switch on the head had a loose wire, reconnected and crossed our fingers.
Ran 4 miles or so performing okay, then started to get worse. Eventually running so rough that you can't really get on plane, and we aren't staying there if we do. Extremely rough idle on maybe 1-2 cylinders.
Pull plugs -- cylinders 1 and 2 are black and sooty, cylinder 3 is wet. Pull carbs -- 2 of the 3 floats are out of spec (can't remember which). Adjusted and rebuilt fuel pump again just in case it was sucking fuel into the crankcase there. Idled great initially, but fouled the plugs by the end of the canal and went back to crap. Seemed to idle okay on the muffs when pulled out of the water a day later.
So, I've checked a few things since then, but am trying to decide how to proceed.
Compression is 120-125 across all cylinders.
Looking into the carbs and squeezing an already firm primer bulb, can't see any fuel leaking into the carbs.
Spark is present, but this was a "pre-flight" check and I didn't pay attention to "strength" or color.
Any ideas on a path forward? I have my thoughts, but would like to hear from y'all before putting my ideas in your heads.
Thanks,
Bryson
Thanks,
Bryson
