6wt saltwater grade reel
17K views 43 replies 31 participants last post by  kkeetr
#1 ·
Hey fellas,
I did some searches but many posts were a little dated. I was just curious what options are out there for a decent 6 weight reel? I know the freestone’s are what everyone is looking for but just thought I’d check to see if there’s other less expensive options out there. I’d love a cork draw bar reel over sealed but seems those are few and far between. Cheers!
#7 ·
I've used a bunch of different reels on my 6wts in salt. Any decent reel will work for the typical 6wt sized fish as they are really just line holders. Where it can get questionable is when you hook a fish way above the reel's weight class. That's were high quality gear really shows it's worth the expense.
Hatch 5+ is probably my fav all around 6wt reel for salt, considering quality and cost. I have a couple of them for that reason.
Abel 5/6 SDF is my favorite of my 6wt reels but they are on the pricey side. The Vaya has a cork drag and can easily handle the typical 6wt fish.
Lamson Guru's are good lower priced reels that I used for years. The drag can get a little sticky on startup but they are great reels that won't break the budget
Also, don't pass up the used market for Tibors and Abel Supers if you really want a top quality cork drag reel at a more palatable price.
#11 ·
Best value I’d say is orvis hydros sl. I’d probably get the size iv over the iii but that’s just me. I don’t have experience with the new hydros reel but I have the sl iv and I use it both on my 6wt and 8wt rods and it feels fine on both. See a decent number of them pop up used so if you’re patient and looking should be able to find one if that’s the reel you choose.
#21 ·
I use also use light 7/8 weight reels for my 6wt. My go to is a Nautilus FWX, which weighs all of 4.1 oz. and balances nicely on my 6wt Mauser Waterman, and I also use a Ross Evolution LT 4, which is like 4.8 oz. or something. Both are awesome reels if you can find them on the used market, otherwise take a look at their replacements - Nautilus XL mentioned by many above and a Ross Evolution R or LTX. Plenty of other great options out there that have already been mentioned!
I like using the lightweight 7/8 reels because I like the safety of additional backing as a lot of 6wt saltwater reels are on the low end of what I'm comfortable with for backing anyway (that's just personal preference). Need for backing depends on what you're fishing for, I guess.
#27 ·
Yep mine are all direct drive versions. I have a salmon,, bonefish, and tarpon. The drag knob is in the center on the same side as the handle.
I run nautilus and tibor signature in sealed drag but love these pate direct drives. They are replacing my old pflueger medalists/orvis madison. I have a collection of those also still use for fresh water.
The drag is adjusted by the gold gear looking thing in the center... reel isn't on a rod.
#32 ·
I run nautilus and tibor signature in sealed drag but love these pate direct drives. They are replacing my old pflueger medalists/orvis madison. I have a collection of those also still use for fresh water. View attachment 193304
what’s funny is I was considering just going with a simple click and pawl reel over a sealed drag simply because it is wide open and would be easier to service than a sealed reel. But I’m not sure how these things would hold up in the salt…
#28 ·
I recommend an American made product like Abel, Tibor for high end and little less; Nautilus, Galvan, Colton, Ross or Lamson. Don't be afraid to use an 8wt reel on a 6wt rod. Makes the reel you choose more "all purpose" for different applications. The real choice will be sealed or unsealed. My choice is unsealed for saltwater because I have been there and done that when the seals on a expensive fly reel can't keep back the fine particles in the water. You are down and out until you can get it apart. Non sealed take it apart, rinse it off and your back to fishing.
