121 - 132 of 132 Posts
Discussion starter · #121 ·
You don't have to have a separate battery for the motor and lights etc if the motor does not cause interference with your fish finder. Also you might think about a backup bilge pump which you can wire direct to the battery with an in-line fuse. I'm not paranoid much :) but I've two bilge pumps wired and a third with wire leads with alligator clips if all else fails.
My marine radio is also wired direct to a battery with an inline fuse
An AGM should be ok for the motor too. I've use one for my 60 merc.
The second battery could come in handy if one fails and you need to get the motor started though.
AGM means absorbent glass mat and refers to the fine glass fiber separator between the positive and negative plates that helps absorb all the battery acid. AGM Batteries are advanced lead-acid batteries.
thanks for your help.
My manual for the Suzuki specifically asks for a lead acid battery at 650 amps. I don’t want to mess around because I will be paying for my motor for the next 5 years.
I will probably get an extra bilge pump. I think I would be more paranoid if I was under the golden gate floating in freezing cold water in the fog. ;)
i made some adjustments to my plans. I have not added the extra bilge yet.
Discussion starter · #126 ·
I think the boat is finished. I have a few minor things but it floats. I know some people will wonder about the motor cover but it is made to protect the motor and has vents for the motors intakes. Thanks for all the help over the last 4 months. I appreciated the comments and suggestions.
Discussion starter · #129 ·
Your ready to go catch some... :)
Yes, I saw birds hitting the water but I did not know what bait fish was getting eaten. I will need to research a little on the lake. I threw a few different lures but no bites. The wind was howling about 20 miles an hour so it was hard to cast.
I also put my fly rod in my rack on the boat. I will have to try it again. It’s a cheap one but I took a lesson with an old timer that pass on a few years ago. He taught me a few things but I have a lot to learn.
Discussion starter · #131 ·
You might look into the new "soft plastic baits". Seems that they are very popular and paired with a quality spinning rod and braid line can cast light jig hooks taking spinning to a new level.
I got a question about where a good place to buy Suzuki parts. I need to do my first month maintenance on the engine and a lot of the places are sold out. I need oil, oil filter and gear lube.
Do you still have a metal fuel tank for sale? Mine is plastic and it sucks.
You should stock a maintenance kit for your motor.
Owners guide will have the hourly intervals and what should be done.
Get the part number of your filter and then do a google search.
There are specifications for oil/lube used for outboards, check these and you can get them from several different manufacturers.
I'm using this brand of plastic fuel tanks along with a fuel/water separator.
