41 - 60 of 67 Posts
Oh sample rub rail I’m gonna use
How are you going to keep that rub rail from slipping off? If you put screws into it, any other boat/dock will get the screw head to rub against it. Keep that in mind when joining up other boats at the sandbar ;)
While I am not sure of this choice, usually the rub rail is thick enough to countersink the heads of the screws or bolts. I would use either a flat head or oval head screw or bolt. https://shop.hamiltonmarine.com/products/pvc-rub-rail-flexible-44379.html I have used a lot of this in the past and plenty thick to countersink the heads of screws or bolts. It says flexible, but anything less than a 12" -16" radius bend, I would suggest using a heat gun to warm it up first. I have done a 1" radius around the transom corners with a heat gun. If anyone would like to see pictures, ask and if the snow is not too deep, I will try to get to the boat for pictures.
Discussion starter · #44 ·
Rub rail was a pain in the ass to put on, but I think now that’s it’s on it isn’t coming off. So if that’s the case I am probably not gonna secure it with screws.
Did raising the floor that high make it rock anymore at speed? how much foam did you need to use? I have been wanting to do all of this but I don't really have the best work area and have little kids so I don't want fiberglass everywhere again. Ugh. Your project looks awesome. Thought about paying but that can get too expensive.
Discussion starter · #48 ·
It was rocking just as bad before as it is now. Under power it will shift a little but it isn’t that bad, still does 25mph after all the wood was placed. I’ve been lazy and haven’t got much done lately. I dry fit the rear deck but I think I’m going to make a few changes. I have two batches for each side, battery going on the right side.
Looking good!
Discussion starter · #50 ·
I was able to get a little more done yesterday. Glassed in rear deck, added strength to transom, epoxied some pipe fittings thru each hatch wall. ( fuel line, electric ) Changed my mind on my previous drain size which was 3/4 inch pipe. Used 1 inch instead and ran a direct line to the rear bilge. I am not finished, I am going to add some more layers of epoxy barrier, with some sanding. Overall, I feel like I am nearing completion, would like to make a small console section in the grab bar for cup holder/switch board, possibly move trim/tilt and ignition button to the console. And extend the tiller arm. I want platform over the engine but having trouble locating where to buy one??
Discussion starter · #60 ·
So I was attempting to run the electric start, kill switch, and power trim switch up to the console box. Everything went smooth except the electric start. I plugged one of the wires back in and as I went to plug the other in it kept wanting to turn over as soon as contact was made. I am not sure if I broke the switch or if the wires are completing a circuit in the sheething of wire that I ran. Im not sure if anyone has run across this problem before or have any ideas of what I should do.
41 - 60 of 67 Posts
