12' fiberglass jon boat conversion
1 reading
12K views 18 replies 7 participants last post by  ianvanilar2020
#1 ·
I received the boat pictured below from a family member with a trailer, new in bow all water minn kita, long tail mud motor. I took it knowing the transom was bad and rats had made nest in the flotation foam in the seats.
Got the idea to open the seats to make compartments with flotation pods. Now I'm wondering how far I can open the deck by removing the seats and going with a bulk head in the bow and stern. If I open it up I'd use to coolers as seats, strorage, and flotation.
Thoughts?
#18 ·
I was finally thankful for finding this post on this website because I have the exact same boat at home that I'm currently working on very slowly. My late foster father gave me this 1976 MFG Challenger 12 after finding out who made it because this boat was missing side plaques and the actual coast guard stamp is gone due to the previous owner ripping out the inner fiberglass transom. Fortunately, it has a serial ID stamp behind the transom upper right. This boat needs a major renovation because the said owner "bubba-fixed" everything the wrong way, I mean, like, steel screws thru the hull to hold the 3 fiberglass seats, many lag screws to hold a 2x8 pressure treated wood to the upper transom. Its one of those WTH reactions when I slowly took off the wood transom and I find a rotten plywood behind it. I also noticed that the gunwale is a rotting rope over fiberglass hull sides like it was part of it. The seats are cracked and I'm pretty sure the flotation foam is gone. I wonder if the flotation foam is in the seats? The entire boat, except the transom is not cored, just fiberglass mats. I am planning to patch up all the holes correctly and replace the gunwale, but with what? And replace the transom to reinforce for a 10 hp outboard motor and either redo the seats or build new fiberglass seats. The transom used to have a 3/4" core on motor mount and 1" core on entire upper transom. Has anybody have done an entire remodel including the flotation foam?
#17 ·
The middle bench is support for the sides. Ever been in a plastic canoe? Think about it flexed[/QUOTE
I was thinking cutting out just 3/4 of the middle bench, leaving the outer shell of one side towards the bow and start my front deck there to keep some of that middle Stength and or add a floor with stringers
#6 ·
I've had the boat for a little over a year and the layout has evolved in my head countless numerous times.
Think I will keep it simple. I would still like to put some storage in the rear 2 seats as well as some flotation. Thinking about anchoring some coolers inside the seat. Would act as dry storage, drink well, and fish box. Not to mention a little flotation should disaster strike.
#3 ·
Those bench seats also help to provide stiffness to the hull (including the bottom). If you remove them all and put bulkheads in, you will be missing the middle stiffener (previously provided by the middle bench seat). You may find the floor flexing quite a bit without it. That was my experience with an old Johnsen 14' skiff I re-configured with a front and back deck instead of the 3 bench seats...
