21 - 35 of 35 Posts
I love my nrx 11wt. It’s a great stick with lots of fighting power plus easy to cast. Have whipped Tarpon to 140, Since your going to a fly shop, suggest you add the NRX s+ to your list of Rods. I haven’t thrown the nrx + but have read good reviews. I just ordered a nrx pro 1 to keep as a boat rod.
Good luck with your rod test and let us know which rod you ultimately decide to buy. Excited for you.
Discussion starter · #23 ·
Thank you. I’ll keep you guys posted.
Discussion starter · #26 · (Edited)
Thank you
I'm stuck between the 11 weights in the 4 piece Sector or Asquith vs. the NRX Pro 1. The rod will either stay in my condo to fish the LGI beach in April through July or from the condo, a short 100 yard walk to my boat.
Never had a one piece fly rod. I can't find a local shop that has all three. The NRX won't be in the shops till earliest mid March, maybe!!
So really not sure what to do, a conundrum. Sounds silly!!
I don't think you can go wrong with either of your choices as both are great rods. Throw the Sector and Asquith to see which one suites your casting stroke best with your reel and line choice. The fly shop assistant may be able to help coach you on the differences between them and NRX pro 1. You will get more sensitivity out of the pro 1 and it is a stronger and somewhat lighter rod and less likely to break due to no ferrules in which individual pieces may not be seated properly. Plus you wont have a piece slip off during a fight or cast which we have likely all had happen with a 4 piece. at least I have. But, if you think you may wish to travel, then the 4 piece is the better option.
Good luck with whatever stick you choose.
Discussion starter · #28 ·
Thanks. I think I’ll wait for the NRX to show up.
I Use A lighter reel nautilus NV but I love my hardy rods. I describe my 11 weight as pulling king Arthur’s sword from the stone .
if u need a 4 piece rod I’m a big fan of the edge rods by Gary loomis . Only issue is they are on lime direct and take a while to ship. A long while
Discussion starter · #30 ·
Thank you for your input! I have heard good things about the Edge rod company perhaps one day I'll be lucky enough to try one.
I should have the NRX PRO 1 by end of March which is fine. I'll be on LGI from the 3/23-4/2. I hope to put that rod to use on some larger Poons when I'm back on LGI in July and August.
Thanks again
Thanks again
Exceptional rod. I’ve had an older edition in the past. if you are ever in South FL dm me and cast my edge rods. You’ll be impressed spin plug or fly!
Hey guys,
My son bought me an Abel SDS 11-12 for my birthday, I need an 11weight rod recommendation.
Any suggestions would be appreciated.
Vinny
Hi Vinny,
I'm late to this post-been out fishing for tarpon and snook! But I've read most of them, and I would echo lots of the other posts: I, and my sons, have 10 and 11 weights in either NRX, NRX Plus, Scott Meridian, and one 11 weight Loomis Asquith. I love, and can easily throw, all of them. The Asquith stands out-light, but powerful and accurate. I DID go throw the Scott Sector recently, and that mimics the NRX Plus, and approaches the Asquith! Very nice rod. If I didn't already have nice toys, I'd buy one. Key items: 1) The fly line that you put on it, and 2) don't know if all of the rods are available in 1 piece; many manufacturers only offer 4, 3, or 2 piece these days. Something else to help you spend more money: Get a second, or even third, spool. Keep a "head heavy" floating line as your main line (SA Amplitude Grand Slam, RIO Direct Core Flats Pro, Chard Tropical Punch), then have a second spool with more of a "presentation" line, for low wind/calm conditions (RIO Technical Tarpon, etc.), or even a "ghost tip" line, i.e., floating but with a clear sink tip. Then have the third spool with an intermediate sink line. I still love my original NRX rods, but these new rods ARE lighter. BTW, even though I try to get them to the boat and release them fast, I was throwing at smaller tarpon with a 10 weight NRX Plus, but ended up hooking a 130 on a 10 weight-NOT RECOMMENDED-and she gave me 12 jumps and tired herself out. She was to the boat in 15 minutes... If they run and you chase them, you can beat them down fast once you are on the fat part of your fly line...
Discussion starter · #35 ·
Hi Vinny,
Thank you Howard. I have an NRX PRO 1 in 11wt on order I also have a T&T rod that I built off a blank many years ago. Its a 2 piece work horse of a stick. I'm excited to get tight on a triple digit Poon this season with my new rod.
21 - 35 of 35 Posts
