1 - 14 of 14 Posts
I’ve casted the Hardy, great stick but I haven’t casted the 9 Meridian to compare, but if it were in an 8wt the nod would definitely go to the Meridian.
Reactions: brokeoff
If I could find the video I would post it. I had a 9wt Zephrus bent almost double on a 40 pound back drum and it did not break. I casted both a couple of years ago and both cast fine, but for my casting style a slight nod to the Zephrus and the fact it didn't break I'll give the edge to the Zephrus. Cast both and pick the one that feels the best to you.
so no experience with the Z but the 9 wt meridian is one sweet stick. the heavy lines bog it down but line it with a rio bonefish or permit and it sings. I have and 8 and 9 and the 9 is without question my favorite... that being said rumors are growing of a pending refresh... I have ZERO direct knowledge to confirm or deny and no source I'd consider reliable but the chatter is growing.
I have both. I agree with Jamie, the meridian doesnt do as well with heavier lines, but feels light and crisp with the right line. The zephrus has a bit less feel, but can bomb a line out there.
I agree as well. My 9wt Zephrus (as well as my 5, 6, and 12) all handle heavier line better. For a true to weight rod/line though, my 8wt Scott is better (don't have it in a 9).
Interesting. I have slightly different opinion. I recently cast both 9wts (mind you this was behind a shop not fishing) with a SA Grand slam line.
I thought the hardy was better inclose and at distance, while the meridian was better in the middle distances.
I felt the biggest difference was in the design of the taper of the rod. The hardy felt to have a softer tip, as well as flexing deeper into the blank, while not being a slow rod by any means. Power was easily accessible with a normal casting stroke.
In the meridian, I felt the rod come alive once more of the head of the fly line was out of the rod tip. Still a very nice casting rod. I was surprised, as this is not what I was anticipating. It could likely be due to difference in taper design between 8wt and 9wt rods.
My obvious disclaimer is that I’m no master caster or rod designer lol!
The Hardy sintrix rods are strong. Not sure about the Scott, so I cant comment there. A downside of Hardy is that it has changed ownership 4 times in the past 8 years (same team of engineers and products managers have stayed with company though).
Both are great rods. The meridian is more forgiving on your casting stroke. I own both of these in a 8wt but have fished both in a 9wt. The 9wt meridian is a completely different rod then the 8wt. As Greg’s video showed the Hardy is a tough rod. I folded one up clearing a T-motor when a dolphin(not mahi) decided to eat my lady fish I had hooked up.
I own 2 Meridians and have casted a friend's Zephrus 9. Would agree with much written above...the Z can really punch some line, but the accuracy and balance of the M series continues to impress me every time I cast one. The M feels super light in your hand and its just a better match for my casting style...
Definitely cast each with your given line of interest...totally different animals! I feel like the Z is much more similar to your Exocetts than a M would be.
1 - 14 of 14 Posts
