Long story short !
I was idling for a long period of time when I noticed oil coming out of the carb air intake ... Looked like chocolate milk ! I quickly stopped running it .
Well everyone is saying it's a head gasket ? I drained the oil and restarted it with fresh oil and put the hose on it and it started on the first pull . Then I disconnected the hose after a minute. Drained the oil and it had water in it again ! ?
I did this two or three times to check because I thought maybe when I changed the oil a week ago I didn't tighten up the drain bolt and water leaked in ? Well that wasn't it .
I even pulled the plugs and turned her over and nothing came out . Plugs looked nasty ! ?
Any help will be greatly appreciated ! Also.. I ordered the head gasket, valve cover gasket and exhaust gasket.
I guess my question is...... Do you guys think it's just a head gasket? And do I need any other gaskets or anything else before I get started ? Also.... I need diagram or info on torking down the bolts and I need to know how to make sure I don't mess up the timing ?
