Yamaha guys
1097 10
Rust Auto part
Auto part Vehicle Pipe Tire Car
Auto part Vehicle Subcompact car Car
2000 Yamaha 60 HP 2 stroke. There is a bracket with 2 bolts that connects the motor to the steering linkage, on my motor they are completely rusted and need to be replaced. Worried about something breaking when I’m on a plane...what is this part called and anyone know how hard it is to replace? I imagine I’ll have to cut the bolts off. Thanks for looking
1 - 11 of 11 Posts
I have a 25hp with the same thing going on. They are actually studs threaded into the aluminum and nuts on the end you can see. With mine one stud can out and one the nut broke loose. I would soak them down with penetrating lube for a week and make sure to get around the aluminum bracket because that will most likely break first. You can look up the part on one of those schematic websites. I think there is one called iboats
Thank you @Smackdaddy53!
Sorry I’m not the greatest mechanic, biggest concern is getting the old stuff off. can I just cut those bolt heads off, then remove the bracket- expose the studs and then try backing them out with vice grips or something? Apologize for the questions just trying to avoid leaving the boat at the shop for 2 weeks for this !
Zephyr Cove is on FIRE!
I would try the heat and penetrating lube trick first. Heat each bolt up with a mini torch and immediately spray with penetrating lubricant which will be drawn in the threads as the metal is cooled. Do this a few times then try to back the nuts off. If they break off just cut the stud off flush and drill the bolts out. You can always drill and tap with a larger tap to accept a larger bolt if it comes to that. If you aren’t comfortable doing that then find someone who is.
1 - 11 of 11 Posts
