Since so many people seem to lean on this forum for engine advice, I figured i would ask the group if they have any ideas or have experienced the same issue that I have had intermittently. Probably 10 or 12 times over the last couple of years I have had the engine die when running. It always re starts up immediately and I do not have any other symptoms. It is almost like you turn the engine off. When it has died, I turn the key off and then restart, it starts immediately. I do not know if I have to turn the key off before restarting or not. I did find a fuel issue with the filter between the fuel pump and the engine(it was cracked and dripping. I have also changed the separator out multiple times. I had it happen since then, so that wasn’t it. The only commonality I can find is that it does this when I’m running wide open or near that. I get no error on my multifunction tach and the motor is peeing like crazy. Any ideas??
Chip
Chip
