1 - 4 of 4 Posts
Just picked up a boat with a Yamaha C60 outboard on it. Standard 3 cyl, 849 cc, 218lbs.
Yamaha also makes a 70 which is identical to this motor except the 70 has oil injection.
Naturally I'd like to look into converting this motor to a 70 if it's something simple and relatively inexpensive.
My question is, have those of you that have done a similiar conversion had any issues down the road that made you wish you hadn't done it?
Carb and intake assemblies are different
http://www.yamaha-motor.com/outboard/parts/home.aspx
Looks like they have a larger carb and intake, yes. Also you gotta watch as they have a "precision-blend" version of the 70 as well.
I would think it can be done if I found the parts (parts for these motors should be readily available on the market), but I'm also wondering if anyone had any regrets once they changed over.
Won &quot;Do More With Less&quot; Award!
I love converting the small portable outboard motors but for C60hp yami 2-stroke....I just leave the way it is.
What's 10 more hp gotta do for the boat? I will invest a better propeller or else.
If 60 - 90hp then I will do it.
My 2 cents.
Good luck :)
1 - 4 of 4 Posts
