Hey RK, been awhile. Sounds like you just replaced the soft components
not the housing or base plate. Might be a small loss of pressure there
due to loose fit. Also could be corrosion buildup, or debris in the passage ways
through the block leading to the tee that feeds the gauge. Or, maybe
a poppet valve that has stuck or worn so that less pressure is needed
before the poppet activates.
