1 - 20 of 30 Posts
2006 Kirkland 17
Hey all this is my first post here - as I am at a crossroad right now with getting my motor running. Looking for some insight and expertise here before taking it to a mechanic.
So some background…bought a skiff with a 2006 Yamaha 50 HP 2Stroke and ran it a week or so after buying it. Ran fine, got up to 5700 RPM at wot. Later that day it would start to die randomly while at idle. That eventually progressed only being able to run the boat around 1500 rpm the whole way back to the ramp. I ended up doing the following: cleaned gas tank, replaced all fittings, replaced gas line from tank to motor, replaced bulb, replaced onboard fuel filter, replaced motor fuel filter, replaced gas pump, cleaned jets and carbs. Took the boat back out and it ran a lot smoother, but then it wouldn’t go past 2300 rpms. This time it wasn’t bogging down or anything, it remained at a steady 2300 at wot - couldn’t even get on plane. Went back to the drawing board… replaced the impeller and thermostat incase it was a temperature thing because it quit peeing one night when I had it on muffs in the driveway. Took the carbs out again, cleaned, and replaced the floats and gaskets. Replaced all 3 spark plugs. Put in new gas with a small amount of sea foam and took the boat out this morning. Now it bogs down and almost dies at 1800 rpm. Idle seems fine.
I am kind of stuck at this point… the only thing I can think of is replacing the spark plug wiring, checking the oil filter, replacing the choke module. Does anyone have any suggestions or other steps I can take to pin down what my problem is now? I find it odd that I could previously run at wot and replaced all these parts and it’s still not fully operating. Your input is appreciated!!
Zephyr Cove is on FIRE!
Do a full carb rebuild with Yamaha parts. Clean all parts by soaking in ChemDip per the directions on the can. Assemble with stock carb settings and sync carbs and run straight gasoline with no snake oil other than oil injection if it still has the system. Make sure fuel pump is rebuilt, fuel system from tank is clean and in good operating condition and if you are skeptical, run on a remote tank with fresh gas and make sure the spark plugs are clean if not new. Also make sure you have no false alarms that are limiting RPM but not sounding the alarm.
2006 Kirkland 17
I basically rebuilt the carbs. I cleaned out the jets by soaking for several hours and blowing compressed air through them. All the floats were replaced with new. All the gaskets were replaced with new. I have been running straight gas since it does have the oil injection system. Fuel pump is brand new. Tank has been recently cleaned, all new lines. What determines if a tank is in good operating condition? It has a vent that is in the fuel line that I fill up the tank with. I will use a portable tank directly to the motor next time. I have new spark plugs. I am not sure what you mean by false alarms... there are no sounding alarms and there are no alarm indicators on the tachometer.
Are there any fuel lines on the motor that haven't been replaced?
I'm assuming the linkage opens the carbs and advances the timing correctly, or is timing controlled electronically? I'm no marine mechanic, just throwing out ideas....
I had same problem. Mine corrected with what you have done. If you have a pressure/vacuum gun such as the mityvac to test the float closing on carb. I used it to pressure fuel inlet side with carb upside down to test the float needle seat holding with something like 4 lbs pressure. I also used it to test fuel pump. I have the Seloc Yamaha manual for 2 strokes which gives good instruction on how to test various parts.
Joe
Basically rebuilding carbs and doing an actual 100% rebuild are not the same thing. Did you replace all the parts that come in the Yamaha rebuild kits?
The jet orifices get varnish build up inside them that restricts the fuel flow by just enough to cause issues no matter what parts you replace. I use a piece of twisted copper wire to clean the varnish out then blow through with carb cleaner spray. Don’t use welding torch tip cleaners as they are too hard and will remove material from inside the brass jet and open it up too much which throws off the air/fuel mix. Copper won’t.
2006 Kirkland 17
No fuel lines that I have not replaced. Linkage and timing is correct (mechanical). I am not a marine expert either, just a Youtube connoisseur (y)
Joe
I do not have a vacuum gun. I am also thinking the floats are not properly seated. When i tried to blow through the gas intake on the carbs it felt as if it were restricted... I am planning on checking that out first.
I am not going to lie... I replaced with an OEM equal part and only replaced the components I spoke of earlier. Everything looked fine in the carbs so I did not want to buy more than what was necessary. I used copper and sprayed carb cleaner through the jets when I cleaned them.
I had a brief conversation with my buddies mechanic today and I am thinking that I did not seat my floats correctly. This is in line with some of the suggestions here as well. Just for everyone's knowledge.... you can crimp your line or pump your bulb when running the boat and find out if you are running lean or heavy. I am going to go ahead and see what's going on with these floats. Anyone have any suggestions as to what to look for with them? I plan on yanking them out tomorrow.
Thanks for all your input so far its appreciated!
floats on 2 strokes don't usually cause a bog. they can cause fuel to run out of the carbs if the float needles aren't seating or the floats are letting too much fuel into the float bowls or they can cause you to run out of fuel at wide open throttle if they aren't letting enough fuel into the float bowls. if it's far enough off to cause a bog you would be losing a lot of fuel into the water.
as smackdaddy said, there is no I kinda/sorta rebuilt the carbs. you do it right and you do it complete or you're wasting your time. a set of acetylene torch tip cleaning drills works great on carb jets just don't go too big a size or too vigorous with them and ream out the jets.
Plastic piece on my linkage broke once. Run like a top but slow to get up and would only run 2800. It was the timing advance linkage.
Small black plastic piece that threads onto rod with ball and socket.
Good Luck !
On that note, floats can crack and fill with gas then you will see bogging
If this were my motor it would be headed to a pro Yamaha tech... and I'd be expecting that the trouble was not your carbs (or fuel system at all....).... Me, I'd be expecting some kind of an electrical problem (charging or sparking...) with the motor itself that was causing it to bog down that way...
Please post up what the trouble was when you finally sort it all out...
2006 Kirkland 17
Discussion Starter · #14 ·
To your point... If the floats are not set to the proper height that would limit the amount of fuel allowed in the bowls. This would result in running lean and bogging down at higher RPMs. Am I missing something here?
And for those commenting on the carb rebuild... I took them apart, cleaned all the jets with copper wire and carb cleaner, soaked everything for several hours, and ran compressed air through the jets. I then replaced the floats and the gaskets. Not sure what else you can do other than replacing the jets - which are clean as a whistle at this point.
You never mentioned replacing the float valve needles. They get eroded where they contact the seat. Once you remove them and put them in differently than they have “worn in” they never seat right again. I have been doing outboard engine work a long time, rebuild diesel engines from scratch, make my own custom parts and fuel systems and work in the oil and gas industry where I rebuild complex regulators and controllers too. These are very simple but one component that is not right will make your outboard run like crap.
I used aftermarket Yamaha rebuild kits one time and will never use them again. I threw all of it away and started over with Yamaha parts and the outboard has run like a sewing machine for the last two years. My fishing time is too precious to be dicking around with junk kits to save $50-60 and lose time on the water and do a carb rebuild twice.
2006 Kirkland 17
Discussion Starter · #16 ·
It says it’s Yamaha brand. I got it off Amazon in order to save time, can’t beat that shipping. Here’s what I ordered.
OEM Yamaha 40-50 2-stroke Outboard Carburetor Repair Kit 6H4-W0093-03-00 Amazon.com: OEM Yamaha 40-50 2-stroke Outboard Carburetor Repair Kit 6H4-W0093-03-00 : Sports & Outdoors
I’ll check the seats again when I check the floats. Any suggestions on the needles and setting them? I am counting down the weekends to get on the water in the keys right now.
if you put in new float needles and new float needle seats there is no adjustment as they are all new. some needles have machined tips and some have rubber tips. they are made to seal with whatever seats they come with. I can't remember on the yamaha carbs but typically you have to set the float level per spec on most carbs, it is commonly done by bending a soft brass tab and measuring the distance the float sits in relation to the carb where the bowl gasket goes. read the instructions for the kit or a service manual to confirm for your specific carbs.
This
And those carb kits look like knock off Yamahas, especially at that price.
2006 Kirkland 17
Discussion Starter · #19 ·
10-4 thats what I figured. I believe the float height for Yamah 50hp is 15mm +/- 1mm. I will let you all know how it goes. Thanks again.
Some get spiritual because they see they light, some ‘cause they feel the heat - RWH
Knock off parts are irritating as hell.
  • Love
Reactions: Smackdaddy53
1 - 20 of 30 Posts
