Yamaha 30 horse lower unit issues
732 8
I was given a 93 2 stroke Yamaha 30 horse buy my father’s boss a while back. The motor came off his dinghy that he used as a tender and has MAYBE 50 hours. Being as it has sat for the last 12+ years, I decided to go ahead and replace the obvious: plugs, fuel filter, water pump, etc.
When I went to drop the lower unit, I could see that it had never been done before and that someone had tried (hairline crack on the cavitation plate and a bend on the other side from hammering). Does anyone have any tips or tactics for removing a lower unit that is positively stuck? Thanks
1 - 9 of 9 Posts
And you are SURE you have all the bolts out? ie is there a bolt under the steering torque tab? I couldn't get my etec 50 lower unit off one time and I was SURE I had all the bolts out. Oops
Reactions: Fritz
I’ve got everything loose. What happens a lot is the shaft gets stuck due to sitting and once you can drop the lower unit even a 1/4”, you can pry things apart. Just trying to figure out the best way to get it started without further damaging the lower unit
rubber mallet?
1 - 9 of 9 Posts
