1 - 6 of 6 Posts
Discussion Starter #3
120 max. But every guage is different
Hmmmm. I have a cheap harbor freight gauge I borrowed and both cylinders are showing about 95-100 psi. It seems a little low but I didn't know if it was because of the pull start only or if the gauge was just junk. I did the test cold with both plugs out and again with only one plug out. Given that they are both dead even, I assume the motor is probably fine. The motor is somewhere in the 400 hour range and suffered an overheat from a clogged water intake in some grass.
It starts on the first pull and seems to idle just fine. Speed and RPM is consistent.
Trying to decide if it's worth investigating further or just run it like it is.
edit- I was reading the gauge wrong.  ::)
Discussion Starter #4
There is a little water coming out of the upper exhaust ports just below the cowling. I'm assuming this is normal, if not maybe a sign of a bad head gasket?
1 - 6 of 6 Posts
