1 - 3 of 3 Posts
I have a 2005 Yamaha 4 stroke 15 hp outboard that recently started getting water in the motor oil.
The motor was acting up the last time that I ran it, so I decided it was time for some routine maintenance. The lower unit oil was perfectly golden, but the motor oil definitely had water in it.
When I hook up the water hose to the backflush nozzle on the motor and cover the pee hole, water drains out of the motor oil drain hole. I also ran a compression test on each cylinder, and both cylinders put out 30psi (at normal cranking/starting throttle).
Anyone have a similar issue in the past or have any advice on what's causing the problem? The two shops that I've called said it could be a number of things, but I wanted to check here first.
Thanks,
Harrison
Sounds like a blown head gasket
That motor is very durable so that should not have Not happened ...
I agree with Noe
But 30 psi seems way low. Most are around 100. I am no expert by any stretch of ones imagination.
1 - 3 of 3 Posts
