SOLD/EXPIRED WTB teleflex stearing
Discussion in 'Sold/Expired Classifieds' started by snooknreds2, Aug 6, 2008.
  1. snooknreds2
    snooknreds2 Well-Known Member
    558
    I just bought my 25Hp merc to put on the crack-noe and am not sure what I need to buy in order to steer the thing (no tiller) and the guy said it was called teleflex system. Is that like the stick steering that I have seen on some boats or is it possible to get it with a helm. Any help would be appreciated greatly.
  2. fishgitr
    fishgitr Well-Known Member
    98
    Teleflex is the name of the throttle cables. Steering cables you can get both ways stick or helm. Which are you wanting?
  3. snooknreds2
    558
    I am not sure yet I am still in the building process and have not thought that far ahead in detail. I have never used or seen in person stick steering so I would like to get some feed back as to what the advantages and disadvantages there are to it compared to a helm....with the obvious one being space and the helm gives you a little bit more to ho9ld on to when hulling azz. Are there any others?
  4. Un-shore
    Un-shore Well-Known Member
    Teleflex makes just about everything for boat controls. when most people say teleflex in regards to steering a small boat they are talking about a teleflex rotary helm. It's basically a mechanically driven rack and pinion system except the "rack" is flexible and is contained in a round housing to save space.
    You pretty much hit the nail on the head with the advantage/disadvantage of both the stick and the helm. What kind of boat are you talking about? Unless I had a side console LT I would prefer the stick over the helm so you wouldn't have a center console to deal with.
    My $.02
  5. snooknreds2
    558
    This is all in preparation for the crack-noe (the crack head canoe conversion into a canoe).
    at this point I thin I will go with the stick steering unless the price is about the same. What does each system go for around about?
    Thanks for the help!!!!
  6. CaptSnook
    CaptSnook Well-Known Member
    77
    I use stick steering on my noe, and it is great. I have rigged in the center. I am guesing the stick will be cheaper, It is basically a stick connected to a steering cable, so would have to be cheaper than console.
    If you have any air boats in your area look at it , it mostlikely has a stick steering system
