SOLD/EXPIRED WTB ---  Half-Round hatch
Discussion in 'Sold/Expired Classifieds' started by krash, Feb 23, 2009.
  1. krash
    krash Well-Known Member
    187
    46
    703
    Looking to find/purchase and install a water-tight semi-circle hatch.
    I have an flush area approx, 9" diameter, but not a full circle instead its just over half circle 5" wide. I'd like to put in a half-round water-tight hatch. Either add a dry bag or small compartment to hold a few small items, area is maybe 12 inches deep.
  2. Brett
    Brett > PRO STAFF <
    Re: WTB ---  Half-Round hatch
    Only half rounds I've ever seen were expensive.
    300 bucks plus on sailboats. Another solution
    might be a 4 inch diameter access port.
    I use the 6 inch diameter size in the Slipper to access the rear stowage.
    http://www.smartmarine.co.nz/ventilation-hatches-inspection-ports-c-791_794.html
  3. krash
    187
    46
    703
    B,
    Thanks for the suggestion, but 4" just won't do it. I need to maximize the opening.
    Actually I need to get access to do a fiberglass repair from the inside.
    The hatch thought was an idea to cover the spot where I need to cut into, and would look better than trying to match gelcoat colors when done.
  4. Brett
    Brett > PRO STAFF <
    found this one...
    http://shopping.ninemsn.com.au/prices/boat-d-hatch-half-round-polypropylene-glass-marine/itemid24234053/?itemtext=itemname:boat-d-hatch-half-round-polypropylene-glass-marine
  5. paint it black
    paint it black Paddling away...
    6,242
    916
    2,328
    I did the same thing when I needed to replace a through-hull fitting that was under my front deck. I just used a 6 inch circle hatch and it got the job done.
