Wood Fly Boxes
1812 Views 25 Replies 17 Participants Last post by  PileatedPhotography
I've been experimenting with some fly box designs. I found precut foam inserts for freshwater boxes, but nothing big enough for large saltwater flies. I tried cutting my own for this one. Made it from some NC walnut. I've got a couple more boxes brewing in the shop with some funky sapele.
Wood Tool Rectangle Wood stain Hardwood
Wood Natural material Rectangle Art Creative arts
Musical instrument Wood Keyboard Musical instrument accessory Automotive tire
See less See more
3
  • Love
Reactions: 5
1 - 20 of 26 Posts
Very nice work - you should check out / repost your work to the ”anything-handmade-fishing-related” thread where others here are showcasing the craftsmanship and skills they pursue off the water.
After that, tell me about the tarpon inlay; How’d you do that - hand carve, router template, cnc? and what’s the inlay material? definitely post the sapele when you’re done, really good stuff.
Definitely need to move this to this thread. Nice woodwork!
Reactions: 1
That's incredible. I'd strongly consider buying one if you plan to sell these, especially one with a redfish or bonefish on it. Any magnetism to keep it closed?
Reactions: 1
Sorry for posting in the wrong thread. I didn't know if I'd be cluttering up the other one if I kept posting about design ideas and new boxes. Next one will go in the correct place.
Much appreciated. In the past, all my inlays have been done by hand. Creating the design in photoshop, printing it out and using an exacto knife to mark the outline. Then a variety of tiny dremel bits to carve out the material. (Shoutout to my dentist for letting me have a couple bits he was done using). All the inlay on this page was done by hand.
It is a very time consuming process and doesn't work as well for small lettering, so I recently purchased a small CNC router to help me. I used it for this box. The material used is crushed turquoise from a mine out in Arizona. A cheap bag of their floor sweepings will last me years. Sometimes, I'll use epoxy, but for thinner lines like this, I use CA glue to hold the material.
I went with Brusso hinges. They're expensive, but much better than anything else I can find. Their precision makes it easier to get proper alignment of the two box halves compared to a $0.75 pair from Lowes. Made up in NJ I believe.
See less See more
Reactions: 3
@PileatedPhotography - just damn! definitely admire (ok, envy, covet) the by hand skills, but understand the use of a cnc. Keep it up, keep sharing and good luck!
Reactions: 1
I know you can buy adhesive backed foam inserts from Umpqua. You might have some luck cutting those to a desired shape. The price probably isn't as nice as what you found but it might be a decent starting point for finding some saltwater sized foam.
Foam Sheet
I'll be sure to post again next time I get some finished. Hoping to have some to sell. Still looking for a good redfish design. You're correct about the magnets. You can see one in the corner of the inside of the box.
Foam Sheet
I've been tempted to try something like this! The adhesive back is great to have. That's how the freshwater inserts that I found are.
Reactions: 1
That is a thing of beauty. I would be interested if you ever decide to sell any. The turquoise tarpon is magnificent.
Reactions: 1
PileatedPhotography, have you looked at sticky backed weather striping at the big box stores ?
the tiny hole at the end of the slit could be made with a small leather worker's hole punch
the slit could be made w/ a wood chisel
NICE INLAY WORK
and your WOOD WORKING aint bad neither ;-)
leon
See less See more
Reactions: 1
Amazing work man! I’d definitely buy on with a redfish if you’re selling in the future 🤙🏼
Reactions: 1
Very nice, if you sell em I’ll get one too! Awesome work
Reactions: 1
5mm craft foam can be found at various locations Amazon/Hobby Lobby/etc. I also thought the Seadek looking stuff in this one looked sharp.
Even if you didn't get the milled out grooves, you could just use a plain sheet of Seadek and cut slits with a razor knife.
Reactions: 1
I've seen boxes like that but wasn't sure what the material was. That might work really well for what I'm doing. I'm going to give it a shot. Thanks for sharing!
1 - 20 of 26 Posts
