Wiring a trolling motor.
Discussion in 'Power it up with Electronics' started by CodyW, Jan 10, 2018.
  1. CodyW
    CodyW Well-Known Member
    425
    134
    168
    I'd like to wire my trolling motor right this time. I have a 24v 80 thrust co pilot and would like to know what all I need as far as fuses or relays. I plan on putting in a 24 volt in board charger also.
  2. predacious
    predacious Well-Known Member
    189
    79
    103
    get a yandina troll bridge 24 and be done with it
    use a blue seas breaker - running from the electrical bridge and the #6 battery cable to the trolling motor plug
    you'll need a simple on/off switch as well - to control the bridge...
  3. Vertigo
    Vertigo Carpe Diem
    1,061
    402
    938
    For 24 volt, 6 ga wire will usually work unless you have an uncommonly long run from batteries to motor. Put a circuit breaker in the positive feed to the motor. The Minn Kota MKR-19 is a good one. It's also a good idea to have a mechanical disconnect between batteries and motor. The Battery Tender 27-0004 plug is the ultimate. The Minn Kota MK 210D charger is what I use, and I'm going on 5 years trouble free with my current one.
    yobata and sjrobin like this.
  4. lpg
    lpg Well-Known Member
    104
    20
    93
    Ok here is a piece of advice I have for you, I had very limited understanding of electricity when I did mine, and could have caught boat on fire. I may still be wrong, but when I wired boat and burned up the jumper wire, I believe now I understand why.
    If you are using a 24v system, (Batteries wired in series). DO NOT, DO NOT put them onto a battery switch with 1,2,both,off. If you do, you will have a dead short upon "both".
    Currently, I have one battery hooked up to the battery switch, which runs motor and accessories. The other battery essentially just sits there(60 amp breaker, no battery switch), and is only connected to other battery via the jumper wire and wiring to trolling motor plug.
    That aside, the only thing you will need is the breaker 6" or close to the positive off battery.
    Have been using the 24v charger from west marine no issues so far. It is mounted in boat, and has a plug where we simply plug in extension cord, shut off batteries, and put boat away.
