what would cause a white streak on my outboard leaking fuel? oil? cant figure out how to put a pic on this so i can email you the pic if you want
then i would say it definitely has something to do with water leaking out and drying on the engine cover leaving a calcium deposit trail. try checking to see if all connections are tight and that the washer is still in the hose connectoryea thats where you hook up the hose to flush the motor
any type of bathroom cleaner that wipes out soap scum and lime deposits.... basically all you have are mineral deposits and anything that will take of that should work. once cleaned i'd give it some wax.... should make cleaning easier next time aroundalright thanks....any suggestions on how to get rid of the white streak?
Plain vinegar. I keep some in a squirt bottle and spray the midsection to soak while I wash the rest of the boat. Household cleaners are much harder on the paint.alright thanks....any suggestions on how to get rid of the white streak?
