Please Select a Boat and Give your Reasoning to Help Me Make a Decision.
  • 1. Ankona Boat: Native 17'
  • 2. Saltmash Skiff: Heron 16'
  • 3. Skimmer Skiff: 16'
  • 4. Saltmarsh Skiff: 1656
  • 5. Saltmarsh Skiff: Heron 18'
Results are only viewable after voting.
1 - 11 of 11 Posts
Premium Member
-I started a thread (link at bottom of this post) for using "Aluminum Boats and Saltwater", and I have exhausted my search by narrowing it down to three aluminum boats to purchase.
-Now I want to touch on five fiberglass boats to narrow my search down, and need your input on these three boats (if you have any).
-Use, flats fishing on West Coast, Florida and Island hopping/fishing.
Thank you very much,
JB
1. http://www.ankonaboats.com/native
2. http://www.saltmarshskiffs.com/heron16
3. 16’6 Rolled Deck - Skimmer Skiff Boats
4. www.saltmarshskiffs.com/sm1656
I LOVE my 17’ Native. Super shallow and rides reasonably well in a chop. I use it mainly in the 10,000 Islands. I have 40 Tohatsu and it will run mid 30’s with one person and right at 30 with 2 people. You’re gonna want to add trim tabs. I also had hydraulic steering added to mine.
What made you choose that model, vs. all the others?
Premium Member
Discussion Starter #4
Since I'm up in age a little and when I had a boat that was not tiller, we used the tel-flex steering (if it's still called by the same name).
Never had the hydraulic steering.
Does that utilize a pump like all hydraulics, or ?
Does it make it that much easier (not worried about a little mussel, but more worried about the complexity of hydraulics and having to fix them/cost in the long run and leaks etc.)?
Yes the Native 17 seems like the winner of them all for the ride/chop cutting (just looking at the bow), being able to go into deeper water etc, as well as the beam/stability.
I keep going back to this model/boat in my extensive search.
Thanks again for the info.
JB
Premium Member
Discussion Starter #5
David, how far do you go on a tank of gas w/the 40hp?
You have a 2Stroke, correct?
Also, did you get the 12gallon fuel tank in the bow?
Thanks again,
JB
JB
I don’t think it uses a pump. I think it just utilizes a pre-charged system with hoses running back to the motor. Because of the tiny console the original cables seemed to always be in a bind so I had my local boat shop install the Ultraflex hydraulic system. The difference is AMAZING! It was a little pricey at $1300, but well worth it to me.
The only issue I have with my Native 17 is it can tend to bow-steer when going downwind with a heavy chop. Not a big deal once you get used to it. Otherwise I’m very happy with mine.
Premium Member
Discussion Starter #8
Thank you very much, I didnt' know that about the steering cables binding etc.
The wife just called Ankona and this is the one we are most likely to go with (SUV17).
Seems to be a good all around boat in case I want to fish some deeper East Coast water etc.
Premium Member
Discussion Starter #9
David, so the hydraulic steering Ankona offers is the same most likely.
Might be a plan for $550.00 add-on option with the side console.
What's the big difference in the hydraulic and the tel-flex? Just the fluid helping you push etc I guess.
Thanks again,
If you’ve never had hydraulic steering it will amaze you. No pressure at all on the wheel when you turn. I would recommend the center console because this is a very lightweight boat that will list noticeably to the side unless you’re always going to have two people on the boat. Also the center will help prevent getting wet in a chop.
Premium Member
Discussion Starter #11
Yes I will have two people 60% I guess but I also want trim tabs. Those should help.
1 - 11 of 11 Posts
