Which non skid is the most more better?
Discussion in 'General Discussion' started by MooreMiller, Oct 11, 2017.
  1. MooreMiller
    MooreMiller Well-Known Member
    73
    40
    93
    What nonskid do you guys prefer?
    I see a wide varity of molded and sprayed non skid out there. Which boats have the best non skid? Good traction and easy to clean?
    Took my buddies newish red fisher out in some sporty conditions today. I lost my footing several times and was amazed I didn't bust it out there.
    My little skiff has raw gel coat all the way around that keeps my feet glued in any conditions. Not too easy to clean, but I can live with that.
    Bonus points for any hilarious incidents!
  2. Vertigo
    Vertigo Carpe Diem
    1,012
    317
    938
    More info needed. Best non-skid for bare feet? Best for footwear? Best cheapest? Best most attractive? Best easiest to install or remove? Best easiest to keep clean? Best for direct sun?
  3. Mike C
    Mike C Well-Known Member
    160
    86
    53
    My buddy Jim can tell you the top of an old Igloo cooler sucks for non skid.
    We were in his 22' Sterling dual console (carpet delete) bass boat at the Sebastian inlet.
    We had the cooler on the floor between the consoles and out pretty much made for level walking from front to rear.
    He was standing on the stern when something very large hit his 12" mullet.
    I was sitting in the driver's seat at the time.
    Jim ran forward and stepped on the cooler with his left foot. It tipped just a bit. As it did his weight shifted right and down he went on top of the windshield back and butt first.
    Thankfully I reacted quickly and grabbed his shirt, keeping him from going overboard.
    He was hurt, but the fish was still there, so no time for pain.
    The fish, well it turned out to be a large jack...
    MooreMiller and SomaliPirate like this.
  4. MooreMiller
    73
    40
    93
    In the market for a new vessel soon. I'm barefoot half the time and the other half I'm in boots. I need good traction when wet on my next vessel. I can't stand feeling like I'm going to slip and fall. Just curious what my options were.
  5. firecat1981
    firecat1981 BBA Counselor
    5,086
    295
    1,938
    I'm not a fan of a lot of the molded in nonskids. Some look great but are still fairly slick, others are a bit sharp on the bare feet, and if it gets damaged it's a pain to fix right.
    I like sanded non skid, the kind that looks like grip paper that is painted on. I have some ground pumice I'll be using on my next skiff. It's easy on the feet and keeps you planted.
  6. predacious
    predacious Well-Known Member
    162
    50
    103
    awlgrip,with grip tex additive
    others are going to suggest other methods - after owning/operating a shop for 20+ yrs,i can tell you what works...
    MooreMiller and topnative2 like this.
  7. Capnredfish
    Capnredfish Well-Known Member
    800
    175
    418
    I have had molded in and like it the best for clean up and looks. The additive method, which I have had in the past tends to look blotchy. That could be the quality of workmanship. And the finish did wear off the top of additive so it always looked dirty. I also don't know what the additive or finish was honestly. But am pretty sure it was gelcoat over something. Maybe the Awlgrip is better.
  8. Vertigo
    Vertigo Carpe Diem
    1,012
    317
    938
    For bare feet, something like Seadeak. For most other reasons, a paint like Interlux Brightside mixed with non-skid additive and properly applied. It's easy if done right, lasts long, easy to clean, has good traction and looks good. I recommend Brightside because it's inexpensive and can be mixed easily to give just about any color you want.
  9. topnative2
    topnative2 Well-Known Member
    2,150
    302
    938
    dri-dek tiles for the cockpit
  10. RunningOnEmpty
    RunningOnEmpty I Love microskiff.com!
    631
    173
    168
    The non skid on my redfisher is very grippy. It looks like it was taped off and done out of the mold with a mixture of gel coat and some kind of abrasive from the factory. It's overkill and a royal pain to keep clean. I wouldn't mind giving up some traction for a cleaner looking boat.
  11. MSG
    MSG I Love microskiff.com!
    430
    89
    413
    seadek for bare feet - awl grip with grip tex otherwise. Adding sea dek was one of the best up grades I ever made
  12. predacious
    162
    50
    103
    that's actually one of the worst products ! it's a single part paint,single part paints,they do not fully harden - read that as it will always be soft.you'll be able to dig a fingernail into the paint,irregardless of using a hardening additive.it's also flat,it will hold dirt and prove to be difficult to clean...
  13. Vertigo
    Vertigo Carpe Diem
    1,012
    317
    938
    Absolute B.S. I've used Brightsides on more boats than I can count and the results have always been good. Brightsides hardens quite nicely, is glossy, and is quite durable and easy to keep clean. Two part paints are much more difficult for amateurs to use, are more toxic, and are way more expensive. Hull and deck in images below finished in Brightsides. The dark grey deck is Brightsides with non-skid added.
  14. CPurvis
    CPurvis Well-Known Member
    320
    99
    163
    I just picked up my boat and I got the AWLGRIP w grip tex. Man that stuff is legit. I am so glad I went with it over seadeck. Now that being said I just got the skiff so I'm not sure how it will hold up. But as of now it looks and feels awsome.
  15. MSG
    430
    89
    413
    It holds up great - mine was "super sticky". I put sea dek over it, though - to me, much more comfortable - but awl grip is really great and durable.
    CPurvis likes this.
  16. Godzuki86
    Godzuki86 FlounderPounder
    996
    136
    168
    E210891B-393A-4F1F-B983-187038FBFED8.jpeg This is what my non-skid looks like. It isn’t as grippy as the roll in style non skid, but it looks great, cleans easy and is not by any means slippery. I just had aqua traction put in the cockpit of my boat so Im looking forward to seeing how it feels.
    DeepSouthFly and topnative2 like this.
Loading...
Similar Threads Forum Date
Waxing nonskid? 17t Boat Yard Basics May 26, 2017
Tiny rust spots on nonskid Boat Yard Basics May 6, 2017
DIY Awlgrip Non Skid Boat Yard Basics Apr 19, 2017
Need a good color to match white for non skid deck. General Discussion Jan 26, 2017
Applying Non Skid to skiff Boat Yard Basics Jan 19, 2017
