First the specs
Type 4-Stroke SOHC 2 Cylinder/4 Valves
Displacement 350 cc (21.4 cubic inches)
Bore & Stroke 59 mm x 64 mm (2.3 x 2.5 inches)
Full Throttle RPM Range 4,500-5,500 RPM
Rated Power 15 HP @ 5,000 RPM
Cooling System Water Cooled
Fuel Delivery 1 Carburetor
Ignition System PGM-IG
Starting System Electric/Recoil
Exhaust Through Hub
Lubrication Wet Sump
Trim Range 4 Stage 8°-12°-16°-20°
Tilt Range 72°
Drive
Gear Ratio 2.08:1
Then the process:
1) Install a tachometer
2) Run the boat with a light load and determine the full throttle rpm with the existing prop.
3) A change of 1 inch of pitch will produce a change of about 200 rpm
more pitch means less rpms, less pitch means more rpms
4) Buy a prop with the pitch that will give you 5200-5400 rpm at full throttle.
Previous post:
http://www.microskiff.com/cgi-bin/yabb2/YaBB.pl?num=1260548288/1#1
