What is your favorite hat and why?
Discussion in 'Off Topic' started by iMacattack, Jul 24, 2011.
  1. iMacattack
    iMacattack busy, too busy
    4,685
    205
    2,268
    Summertime is hot and the sun is in full effect. Being "follicle'ly" challenged I am always looking for a better hat. I have a closet full of regular baseball hats. A small selection of soft brim booney hats.
  2. noeettica
    noeettica Well-Known Member
    3,708
    116
    2,268
    http://www.essentialapparel.com/dorfman-pacific-coolmax-solarweave-boonie-hat.html
    This Hat !
    It was field tested by a Large of Outdoor Professionals An order of 1000+ Hats
    Columbia Makes GARBAGE !!!
  3. Brett
    Brett > PRO STAFF <
    Columbia Sportswear with adjustable headband and chin strap.
    Spring loaded adjustment clips stay where you set them.
    Fits comfortably and snugly around your head, stays put when running to the next spot.
    Black underbrim to eliminate glare. I prefer the khaki version to hide the dirt and stains.
    To wash I half-fill a tupperware container with warm water and a dab of dish soap.
    Shake well, let soak, shake again, rinse well, air dry.
    btw, I recommend a bandana be worn between your head and your hat.
    Soft brim doesn't bump my scope either... ;)
  4. noeettica
    3,708
    116
    2,268
    Bret glad you are having better luck than me
    these boots have less than a weeks use and I am getting no relief from Columbia ...
  5. Frank_Sebastian
    Frank_Sebastian Well-Known Member
    787
    2
    Dave I have glued a boot with a similar flaw with "Shoe Goo" I have also used it to glue other things together. Back when I played tennis almost daily I used a tube every two weeks trying to get extra mileage out of my shoes.
    Frank_S
  6. anytide
    4,293
    697
    1,968
    Terlingua - (10X) Bangora Straw Cowboy Hat
    -bangora's best hat ever made -water tight -last forever
  7. out-cast
    out-cast Well-Known Member
    896
    I use this style for yard work and fishing......or...
    http://www.thehatco.com/Lifeguard_Hat7363.html
  8. Brett
    Brett > PRO STAFF <
    Dave, that's 'cause I only buy the hats. My feet prefer no shoes or flip flops.
    The one pair of "real" shoes I own is for dining out and social necessities.
    Not surprising, after 6 years, they still look like new.
    (my steel toe work boots don't count as shoes, they're safety equipment)   ;)
  9. DuckNut
    DuckNut Brandon, FL
    4,687
    514
    1,968
    Frog Togg cooling hat. Get it wet and it helps to keep you cool and is about $10.
  10. iMacattack
    4,685
    205
    2,268
    Well, I've decided to try something new.
  11. Charlie
    Charlie I Love microskiff.com!
    348
    Tried that hat for kayaking. Epic fail. Fabric didn't stand up to saltwater and kinda started to disintegrate. I have an OR hat which has been through thick and thin. Can't remember the model though..... ;D
  12. paint it black
    paint it black Paddling away...
    6,245
    919
    2,328
    This is my favorite hat.
    I was always a visor guy until I bought this hat.
    Since it's a trucker hat, the mesh in the back, it still allows for air to get through.
    Another reason is I always seem to do better when I wear this hat in particular over any of my other hats.
  13. noeettica
    3,708
    116
    2,268
    OR has had some good stuff in the past ...hopefully it's new stuff is still good ...
