I’ve seen several posts about liquid rollers being discontinued recently and can’t seem to find it anywhere. Just curious to see what others have been using in place of this? I’ve been told food grade silicone works well.
Worked well for me too. And only 5 bucks a can.Blaster Silicone works good. As mentioned above spray after you launch and let penetrate while on the water.
Well, I don’t get sand trapPed between my hull and the bunks and I’ve been doing this for years with zero wear. You can get sand trapped, very easily on carpet, been there done that. Boat gets dunked in and is sand free, bunks are sand free, when it goes back on it’s sand free and the boat is sand free. Don’t see a problem. I also have a washdown system for my trailer that I use every time I launch to get the salt water off. Water and saltaway, spray it down in less than three minutes. Looks brand new and so does my hull. This was one of the things I talked to the company about when I first consider doing this. They said sand gets trapped much easier on carpet. I don’t know, I’m gonna keep doing this as it works for me. Using this system, I haven’t had to replace carpet, bunks or hardware on my trailer and doesn’t look like I will have to for many years to come.And sand trapped between those bunks and your hull makes sandpaper. Been there, done that. No matter how well you strap the hull down you’ll get serious wear on the areas where the bunks contact the hull, especially the fronts.
Nice!Well, I don’t get sand trapPed between my hull and the bunks and I’ve been doing this for years with zero wear. You can get sand trapped, very easily on carpet, been there done that. Boat gets dunked in and is sand free, bunks are sand free, when it goes back on it’s sand free and the boat is sand free. Don’t see a problem. I also have a washdown system for my trailer that I use every time I launch to get the salt water off. Water and saltaway, spray it down in less than three minutes. Looks brand new and so does my hull. This was one of the things I talked to the company about when I first consider doing this. They said sand gets trapped much easier on carpet. I don’t know, I’m gonna keep doing this as it works for me. Using this system, I haven’t had to replace carpet, bunks or hardware on my trailer and doesn’t look like I will have to for many years to come.
According to the inter-webs...Not sure what the difference is between "food grade" spray silicone and "Industrial" spray silicone like this Blaster. "Industrial" sure sounds better than "food grade"!
Yeah I’ve been there as well. Sprayed my bunks down pretty generously after launching the skiff one day then when loading it back on the trailer I had to leave it throttled forward to be able to get it hooked where it wouldn’t slide backwards.I experienced the same thing when I sprayed my bunks. I sprayed the back half of the bunks, and she slid off when I took the winch strap off. Then when I loaded, I had to leave the boat in gear while I leaned over the bow and connected the strap. Take it out of gear and it slides right back into the water. Be careful out there!
If a boat is properly tied down and secure, it shouldn't move, period.Great post!
For those that have waxed their trailer bunks, does the boat move side to side on your trailer while towing? That’s my only concern, but if it doesn’t - I’m doing this for sure. Thank you.
