Guest
·I usually fill about 3/4 +/- to save on some bulb pumping.
I wouldn’t, they are also fuel filters so you have dirty filter media being re-used which isn’t worth saving $15-20 in my world.Since the topic has been so eloquently broached, I'll go ahead and ask the dumb question here: Can those filters be emptied of water and refilled? Years ago a friend told me he just dumps them periodically and reuses them; he claimed that he never had any problems doing that. I never took the chance, they just aren't that expensive. But this thread got me wondering about that again. So, are they reusable or not?
I didn't know they offered a composite version, I've only ever used the aluminum. How long have you had this one? I might use that in my Conchfish build.I wouldn’t, they are also fuel filters so you have dirty filter media being re-used which isn’t worth saving $15-20 in my world.
I like the Moeller Clearsite filter with composite head. You can see and drain off any water that might have gotten into the fuel system and carry on. The clear bowl gets re-used and when you buy the upper replacement filter it comes with a new o-ring for the polycarbonate bowl.
If you don’t have the clear drain bowl you have to pull the entire filter and dump into a jar to check for water.
Buy this and use brass hose barbs and plugs, not the aluminum ones that come with it.
https://www.amazon.com/Moeller-Separating-Filter-outboard-Composite/dp/B000MTCQMY
I had one on the aluminum boat I “built” about 5 years ago and have had one on my current boat since I bought it and upgraded everything about 3 years ago. I see these aluminum and steel heads with paint flaking off and rusting and it makes me uneasy.I didn't know they offered a composite version, I've only ever used the aluminum. How long have you had this one? I might use that in my Conchfish build.
Yes, I definitely like the filter/bowl setup. Mostly curious as to the longevity and build quality of the composite option.I had one on the aluminum boat I “built” about 5 years ago and have had one on my current boat since I bought it and upgraded everything about 3 years ago. I see these aluminum and steel heads with paint flaking off and rusting and it makes me uneasy.
The cool thing with the drain is it has a hose barb so you can stick a hose on it and run it out your hull drain and into a container. No mess in the hull.
Only about $45 for the whole setup on the link above. Keep the aluminum one for backup.Yes, I definitely like the filter/bowl setup. Mostly curious as to the longevity and build quality of the composite option.
It would be nice to see a composite head be built/marketed/QCd as a premium "corrosion resistant" option rather than a cost-savings option. I have a spare aluminum head, maybe I should just blast the paint off and get it anodized or something.
