Water Proof battery powered Led Strip
1781 4
Just wondering if anyone has used these water proof battery powered led strips as under gunnel lights. Trying to keep the skiff as simple as possible. Pull start engine and a single small battery to trim tabs. Im not trying to add any more wiring or switches to the boat. I figured I would install the Led string under the gunnel in a non permanent way and have the small 3 AA battery pack and on off unit under the back floor with velcro. will have to turn on each side separately. At $20 bucks a strip it should be an inexpensive and removable solution? If anyone has experience with these lights let me know would be interested to hear any feedback.
Not sure I can post ebay links but these are the lights.
200cm will cover an entire under gunnel side perfectly
http://www.ebay.com/itm/RGB-LED-Strip-Lights-with-Battery-Box-Waterproof-Craft-Hobby-Light-50-200CM-/181515128113?pt=US_String_Lights_Fairy_Lights&var=&hash=item2a43250d31
Thread Killer
I purchased a similar product from Flea Bay and have not had any problems. I actually purchased one with a remote that changes colors, had to take apart transmitting box and split and solder new wires to split the wires and led strip for each gunnel
