First post!
I recently purchased a used 2013 East Cape Vantage VHP, while the boat has been great I've had a couple issues with wiring. I'm not complaining, these things happen with used boats, especially saltwater boats. Most of the wiring stuff I've been able to fix with some soldering and heat shrink. The only persistent issue is the Garmin 740s would power down every time I started the Evinrude 150HO. I had the starter/house battery tested and replaced at Autozone but it kept happening. I just got in the habit of waiting to turn the GPS on after cranking the outboard. Well, the wife and I went out to the local lake this past Saturday and the GPS wouldn't even power on. I'm assuming it could be the fuse/fuse block since I noticed some corrosion on the top left three fuses but I have no idea how to check what is wired into what terminal (it's not labeled). I'm pretty terrible with wiring and only know how to solder from messing around with it while learning to weld in high school.
A replacement blue seas fuse block is $40 off amazon and I will probably have to spend a whopping $2 in fuses, so no biggie. I just need a schematic so I know what goes into what and so I can label them for the future.
