I've added wedges to a transom once in the distant past. It was on a 150hp motor, though. Worked out very well.
Rich
Item #: 20122
Reg. Price: $ 40.99
Our Price: $ 36.99
Description
CMC, Transom Wedges/ Setback Spacers
These 2 degree wedges are designed to give extra positive or negative trim.
Features:
Used as an aid for boats with an insufficient transom angle or for boats having planing problems at low speed
Unique design of the CMC Transom Wedges allows you to also use them as set back spacers
Simply stack and invert 2, 4, and 6 sets (sold in sets of two)
Fit all Transom jacks, jack plates, Outboard lifts, tilt trim units, and outboard motors with a standard B.I.A bolt pattern
Made of strong 6061 T6 alloy aluminum (not cast aluminum)
Will not crack like cast aluminum
