1 - 9 of 9 Posts
does anyone know if it’s possible to swap a minn Kota tiller style trolling motor onto an ipilot or copilot style mount? Curious because I see ipilot parts pretty frequently for sale locally. I like the more compact look of the mount
Anytide fabricated a mounting adaptor for me. schematics below (we did tweak the measurements a bit). i had to add pockets with a forstner bit to keep the clamps from slipping. works great.View media item 5522
Awesome! I had a feeling someone else had my idea! For some reason it won’t let me view that file. Would you happen to have any pictures of it complete?
following. Looking for the same thing as we speak. I was planning on getting a new mount but if i can use my old, could help save some cash. My issue is i have a lip above my casting deck so i would need to put a plate then a quick release mount.
You want to take a particular tiller-style head unit/shaft/motor and insert it into that mount? I think you should be able to. When I received the motor pictured upon shipment, it had a cracked "hinge bushing" that fits around the shaft and inside one of the two rings on the bracket that you see. to replace that bushing, i had to remove the head, disassemble the head in order to disconnect the wires, then pull the shaft out of the bracket. only then could i fit the bushing over the wires and onto the shaft before reinserting the shaft through the bracket. so the head unit/shaft/motor was completely separated from the bracket. If you can separate your head unit that way, dont see why you couldn't slide the shaft/motor back into the mount you want and then reconnect the head unit.
Discussion Starter · #9 ·
You want to take a particular tiller-style head unit/shaft/motor and insert it into that mount? I think you should be able to. When I received the motor pictured upon shipment, it had a cracked "hinge bushing" that fits around the shaft and inside one of the two rings on the bracket that you see. to replace that bushing, i had to remove the head and then disassemble the head in order to disconnect the wires. only then could i fit the bushing over the wires and onto the shaft. so the head unit/shaft/motor was completely separated from the bracket. If you can separate your head unit that way, dont see why you couldn't slide the shaft/motor back into the mount you want and then reconnect the head unit.
Exactly that’s what I’m thinking
1 - 9 of 9 Posts
