I'm sure some of you have the same dilemma I do with the smaller motors. My trailer does not allow me to use the standard transom saver to trailer the motor in the up position. I have no PT&T, and do not like the idea of using the Yamaha tilt lock unless there is another way to support it. I'm trying to avoid fabricating/welding a bracket to the trailer so the traditional style will work. Any ingenious alternatives? Problem is my roller in the rear will not allow the C-shaped section of the transom saver to mount to. The boat sits right on the roller when loaded. Thx!
