Ok, I'm about to start cutting a fiberglass hull that I have to modify it into a skinny skiff. My goal is to widen the entire back half of the hull to at least match the beam in the middle of the hull where it is the widest. It only has a 48" beam in the middle. I also have to make the rear as of the hull as deep as the middle too. I added some pics of the hull. The blue tape lines are where I have to make all the cuts that I have to make to widen & deepen the rear. Also to extend the V shape all the way to the rear to create a shallow V in the back half.
My question is can I go wider than the beam is in the middle? Most of the skiffs on here that I see are the same beam or slightly narrower at the rear. I assume that's for better turning while polling & top end performance on plane. Can I make the stern slightly wider than the middle where it's 48"or will this have some disastrous effect while moving under power?
