1 - 20 of 20 Posts
Is having a transducer worth it? I’m looking at getting the Lowrance elite 7 and I really only want it for maps and things like that, I pretty much always sight fish and I’m poling as skinny is I can get, so I’m just curious should I go with my original thought and skip out on the transducer and add it later if I realize I want it or will having a transducer be extremely helpful??
I have the Simrad-use for maps only, no transducer for the same reasons above
I'm considering one with the plotter only. No need for a transducer when running a tunnel. I just want to lay down some tracks I can follow consistently.
Banned
Sounds like a really expensive chart file w/ o transducer. there has to be a better way . Must be a skinny trick. I ve never heard of such. With all the smart phones out there ,it shouldn’t be rocket surgery Shoot thru would provide best of both worlds
Very rarely use my electronics while salty , mostly inshore striper fishing. I’m learning everyday
I have an elite 9ti that I use just for charts. I never installed the transducer for the same reasons you stated.
That being said, the side scan is great for fishing deeper water if you are into that sort of stuff. Finding tarpon under a bridge or snook under a dick is almost unfair with that thing
interesting, never thought to look there for snook..
lol
I have always put both on. You put a switch on the dash to switch between them. Use thru hull running and the transom for actually looking around with side imaging. I also put an external antenna directly over the transom transducer. This ensures when you mark something on your graph and mark it as a weigh point you can return to it and not be several feet off the mark making your casts.
Also when not graphing and actually fishing turn off the sonar so the fish don’t hear it in shallow water. You’d be surprised how loud sonar is.
Im kind of inBetween on weather or not one is worth it. As others have said, knowing water temp and for unknown waters it’s a great tool but for most skiffs i think it might be a little bit overkill. I broke my transducer off a couple months ago (winds shifted and got stronger while retrieving solo and my boat was under the dock by the time I backed the trailer in) and haven’t reinstalled since and haven’t looked back.
I don't have anything up to date in the way of electronics on my old Maverick skiff - but two things I would hate to be without are my depth and temperture functions (on my ancient electronics they're separate...). The only thing I use the depth finder for is verifying I'm running where I should be in all circumstances - particularly at night....
Water temperatures are everything in the 'glades - at least all seasons except summer (when the water is so hot in the afternoon that I'm surprised whenever we get a bite in the interior... during almost any summer afternoon).... In winter, a degree or two warmer water may hold half the fish in a big area... Without that info I'd be very seriously handicapped...
1 - 20 of 20 Posts
