Removed a Garmin gt54 transducer to put on trim tabs. I’d like to put it back on but space is extremely limited. See pictures below of being loosely mocked up.
Between the tabs I’ll be interrupting the props path. Potentially causing performance issues.
On the outside of the tab it looks silly, damage seems more likely, bottom of transducer will be slightly above trim tabs and may cause interference?
Had an airmar b150 thru hull on order but want the additional features the gt54. Any suggestions? Thank you!
