1 - 3 of 3 Posts
I broke the connector from my trailer to the vehicle plug. I need to order a new wiring harness (connector) for the trailer. Here lies my issue. It’s a 4 pin connector, but has 6 wires. The lights are wired left and right, so two brown wires. However, I also have two ground wires (white)? Does anyone know where I can find a replacement? I didn’t even see this setup on the wesbar website. Can I splice the two ground wires together into 1?
If it ain't broke tweak it a little....
Like Rob said it will corrode eventually but you'll probable need another plug before splice corrodes if you solder and use Marine (glue lined) heat shrink. HF have a nice little kit of Marine heat shrink 42 piece set for 6 bucks.
1 - 3 of 3 Posts
