1 - 20 of 40 Posts
· I Love Skinny Water
This is a beat to death issue but I'm going to post it anyway
My left back light went out after my last trip to Fl and dunking it for 5 days
I've been looking for a tin coated copper harness because the copper wire rots after about 5 years. I'm not putting just copper wire back on there
So I'm going to get a new light and patch it up during fishing season then this Fall I'll tackle this. I'm not a trailer light expert but there's wire on there now I just have follow it and replace it
My biggest problem is finding a tinned copper harness
· Registered
· Registered
Google is your friend:
Nearly all trailer light problems are due to grounds. I don't agree about wiring where nothing gets wet - its a boat trailer, it is supposed to get wet. Use water proof connections, get something that solves the ground problem, run LEDs.
Good point about grounding. I somehow never could get an acceptable ground through the hitch to my truck chassis, so I made a short jumper using large gauge wire and clamps like you would have on jumper cables and clamp one end on the trailer and the other end to a good ground point on my truck chassis and I haven't had a problem since.
Discussion Starter · #12 ·
Also most harness come 18' I need one longer and tinned copper. I guess I could use my 14 gauge to make it longer
· Premium Member
I just got two 100 ft spools of 16 awg tinned wire.
One at $13.89 and one just over $15.00 delivery included.
didn't get it for the trailers but would work there too.
Prices very widely but if you check ever few days you can get a deal.
Discussion Starter · #14 ·
Thanks @mro where did you get it. Also you will need 3 wires. I may just stick with 14 gauge to last longer
Reactions: mro
· Registered
1999 Carolina Skiff 16
Check the gauge wire used in the light. I bought some once that had 20 or lighter wire in the light....lasted about a month. The harness was 16.....foolish to have bought it
Discussion Starter · #18 ·
I try to go back as far as I can to use 14 gauge
· I Love microskiff.com!
1820 Action Craft
I agree 100% about tinned wire. I bought 2 strand 14 ga tinned wire from West Marine right off the spool. Got about 50' of it and made my own harness. Bought two LED lights and it has works great the last several years. I got to agree with everyone that a lot of the problems are associated with the ground. I think if I were to do it again, I would just get 3 strand and run an independent ground to the lights rather than grounding them to the trailer. But either way, get tinned wire, it last so much longer than the non tinned crap they sell for trailer harnesses.
1 - 20 of 40 Posts
