Recently learned from Chittum that you can momentarily reduce the idle on Tohatsu 50 (I’m sure new 60 and probably other HPs too) by pressing the ignition key and holding it a few seconds. Sometimes there is a beep once idle goes lower. In my experience the normal idle is about 1000 RPM. When you press the key and hold, it drops to 750/800 RPM. After running at higher RPMs, the default idle goes back to 1000.
So far I have only had great experiences with the Tohatsu 50 4 stroke. Can’t wait to try the new 60.
