1 - 9 of 9 Posts
SeaArk 1860 MVT
I bent the shaft this weekend on my 2000 Tohatsu 30hp two stroke. The housing seems to be ok, any suggestion on where to get it fixed? I heard Admiral C&B propeller  can straighten it.
A few pics of the boat.
I've never attempted to straighten a bent shaft.
Figured if it took a shot solid enough to bend the the prop shaft,
it was probably better to replace the shaft along with the seals and bearings.
I'd be curious as to the price difference between straightening and replacing... :-?
Check here for part numbers and get a quote for a new propeller shaft.
http://www.tohatsuoutboardparts.com/
It is likely 346-64211-6 They will respond to your request rather quickly. If you can install it yourself it will save a lot. You may have to shim a little.
Best regards,
Frank_S
SeaArk 1860 MVT
Thanks, I wish these parts were easier to get. I almost feel like its faster to buy a used tohatsu on Craigslist for parts than try to work with the dealers. The good news is that I have two boats and I can still fish in the mean time.
That's what I would do!
i had mine straightend for a 40hp and it was a little more than $200. i didnt take it out like you did, so it may be a little cheaper for you.
btw, ive hit a few things/sandbars and its still straight as an arrow since the work
1 - 9 of 9 Posts
