I am considering a fly line toe rail for my Mud Minnow. Any pros/cons I need to consider? Also, what are some material suggestions for a DIY job?
Thanks
for a cheap diy you might consider a few pieces of 1/2 pvc capped on both ends then screwed down to the deck :-/
How long are you thinking they need to be? Some kind of plastic board cut into a strip about 1.5" maybe. You can buy starboard at West Marine.. This might sound crazy, but I think I'd check a local restaurant supply co. to see how large they make cutting boards? Cut it down, use a round-over bit on a router for the top edges.
Two strips of 1/4 ply epoxied together in the shape you want. Shape edges, then coat the whole thing in epoxy. Fair if needed. Paint color du jour and install.
Exterior PVC trim, many shapes and sizes
available at the local home improvement store.
Flexible, can be cut or shaped with standard power tools
waterproof, no rot, cheap...
Appreciate the ideas fellas. Definitely gives me some research to do.
dang why didnt i think of that :-/ bretts right though... i'd go to lowes or home depot as they have a lot of plastic house trim pieces that can be shaped pretty easy
