1 - 15 of 15 Posts
· Registered
I have recently picked up my first boat. Its a 16' Whites Fiberglass and it has some oyster rash on the belly. Some seem fairly deep. I am new to boating but I am fairly handy and believe in doing what you can if you can. I've had one "online expert" say just sand the bad spot smooth and repaint while its on the trailer. I've seen a few guys talk about flipping the boat and working on it that way. I'm terrified of putting any excess force in places where it may compromise the integrity of the fiberglass. Also, if I do go down the road on painting does anyone have a suggestion on paint. I have a friend that can get a good discount at Sherwin Williams but I saw a thread that made me think that is not the easiest route. Any suggestions or input would be greatly appreciated.
· Registered
Is Sherman Williams related to Sherwin Williams? :D
I have a ton of oyster rash on my hull and plan on prepping and applying Marine Tex to fill them in but I am all over shell fishing where I am.
o_O I wish I could say that was auto correct but hey you learn something everyday! I live in north GA but I run down to Grand Isle at least once a year to hit the march. Lots of oyster beds plus my lack of experience polling means this may be an ongoing thing.
· Banned
Marine Tex. Razor blade to remove excess Nothing simpler
All sorts of color filler available. I’m a Benjamin Moore man , wouldn’t put Sherwin Williams on my house , much less my boat. If you paint it , just one more thing to keep up. Never been a big fan of painting trailer boats Good luck.
· Registered
Ok so I like the idea of patching holes with the Marine Tex. What do I need to know about painting a trailer boat? I have a black bottom so should I go with the higher strength gray and maybe paint to match down the road or go white and mix to match the paint?
· Fine line between recreation and degeneracy.
1978 mako 17
Sand around repair area. Fill with thickened epoxy (you can used fumed silica to make thickened epoxy). Use 2 part epoxy paint (awlgrip, interlux, etc.) Below the waterline is not to be trifled with. The whole repair might run you 150 in materials but please don’t use house paint on your boat. Small repair become big repair.
· Registered
Check this out for a graphite/epoxy bottom.
http://tomangelakis.tripod.com/graphite_bottom.htm
In the above article is the following:
West System recommends 10% graphite to 90% epoxy. Gilpatrick uses a thicker mixture of 40% graphite to 60% epoxy. Ted Moores, in the 1997 edition of Canoecraft, suggested 25% graphite, 5% silica, and 70% epoxy (for "a rock-hard finish." p.137). I went for a very thick mixture with the consistency of tar. The following ratios are approximate:
First coat: 25% graphite, 15% silica, 60% epoxy.
Second coat: 30% graphite, 10% silica, 60% epoxy.
Third coat: 40% graphite, 60% epoxy.
My question is this: what are the percentages based on? Weight? Volume?
Within the next few weeks, I'll have the bottom of my boat fully prepped to apply epoxy & graphite. I'm considering adding some silica to the first 2 coats.
1 - 15 of 15 Posts
